LDAP Error message
Jun 21st, 2010
We have a CUCM 7.1 cluster & Unity Connection 7.1 both integrated with Microsoft AD. All is working fine & has been for several years........but i just noticed something recently when i forced a manual sync.
It comes up with error "Failed to Connect to ldap://<IP ADDRESS>:389" and also "Update Successful". The IP address in the error message is the IP of the redundant AD server. This same error appears on CUCM & Unity Connection when forcing a manual sync.
So my question is.....is this normal behaviour? Will it only connect to the primary AD server unless it is unreachable?
I can ping both AD servers from CUCM Publisher
T.I.A
Russell
htluo Mon, 06/21/2010 - 05:53
Maybe port 389 was disabled on the redundant AD?
You may test the port connectivity by using telnet from Windows command prompt.
telnet ip_address 389
Michael
http://htluo.blogspot.com
rchaseling Mon, 06/21/2010 - 08:43
Thanks Michael......shouldn't have believed client's assumption that there was nothing wrong with the AD server without first checking it myself
Reboot of AD server fixed issue
