Redistributing BGP into EIGRP
Jun 21st, 2010
  • Purple, 4500 points or more
All,
I have a scenario that I've been playing around with that compares the functionality between using iBGP vs. EIGRP in a failover setup. So far, iBGP proves to be more "customizable" in the fact that I can do conditional advertisements. The problem that I run into is this:
I have 2 routers and a L3 switch that currently runs BGP. One router (Router A) has a DS3 connection to the provider and a LAN connection into my switch. The other router (Router B) has only a LAN connection to my switch and a LAN connection to a MAN. With EIGRP, when I shut the ethernet interface on Router A, everything converges very quickly (much more quickly than with BGP). But, when I shut the serial side on Router A, the LAN side is still up and eigrp will eventually converge, but it takes a MUCH longer time. Is there something, route maps/distribution lists/eigrp options, that will allow me to do something like a conditional advertisement with eigrp? What I'm currently doing to make this faster in bgp is a conditional advertisement that says if the serial side subnet is missing, then deny advertising any routes. That forces all traffic through my backup router (Router B).
Thanks!
John
Laurent Aubert Mon, 06/21/2010 - 19:24
  • Cisco Employee,
Hi John,
How do you learn your WAN remote subnets on router A (from the DS3 link)  ? EIGRP should still be faster than BGP.
A diagram and the config could help.
Laurent.
Tharak Abraham Tue, 06/22/2010 - 22:49
  • Bronze, 100 points or more
John,
You should be knowing that BGP detects direct failures slower than EIGRP.
You need to manipulate the bgp timers for that, if i correctly understood your scenario.
Or
You may even consider IP SLA usage.
