Air-Ap1230B POE Problems
Jun 21st, 2010
I recently had a switch fail.  I decided to upgrade it to a Netgear 802.3af POE Switch.  I figured it would work with my access points since they were using the cisco power injecters (model AIR-PWRINJ2).  For some reason they will not power up using the switch.  Any help would be appreciated.
Overall Rating: 5 (1 ratings)
