Switch stops providing power on PoE ports
Jun 21st, 2010
We have a C3560 running (C3560-IPSERVICESK9-M), Version 12.2(53)SE2 which is the newest IOS for this model.  Yesterday our POE phone lost power and I was able to find the following bug :
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu58581&from=summary
The recommendation is to upgrade the IOS, but the IOS we have is the latest & greatest.
Any ideas?
By the way, a reboot solved the problem, but we cannot afford to reboot this switch during business hours
Edison Ortiz Mon, 06/21/2010 - 07:38
  • Hall of Fame,
    Founding Member
Try with 12.2(44)SE6 unless you need some feature that can only be found on (53)SE2
On any case, I suggest opening a TAC case so a proper bug can be filed.
