Can't find MD5 for CUCM upgrade 7.1(3)ES31
Answered Question
Jun 21st, 2010
I'm looking for the MD5 value on 7.1(3)ES31 (UCSInstall_UCOS_7.1.3.30000-1).  Is it 1b2af45a842ac686492d2c0cd5aae85b  ?
We are running CUCM version 7.1.3ES26.32900-26 and going to upgrade to 7.1(3)ES31 (UCSInstall_UCOS_7.1.3.30000-1).  I was sent the links from TAC and given the MD5 sum for the two files.  Now that I've combined the two files the MD5 sum is 1b2af45a842ac686492d2c0cd5aae85b .  I'm looking for confirmation that is correct.  When it was published for us by TAC they only provided the two individual MD5's before they were combined.
Mike
Correct Answer by Jaime Valencia about 6 years 7 months ago
The final file should have MD5
1b:2a:f4:5a:84:2a:c6:86:49:2d:2c:0c:d5:aa:e8:5b.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (3 ratings)
Jaime Valencia Mon, 06/21/2010 - 08:24
That's no ES. It's 7.1(3b)
UCSInstall_UCOS_7.1.3.30000-1.sgn.iso_part1of2
Release  Date: 15/Dec/2009
Cisco  Unified Communications Manager 7.1(3b) part 1 of 2 (non-bootable) -
From README
b. If you have a Windows system, copy and paste the following command into the command prompt
(cmd.exe):
Step 3 Use an md5sum utility to verify that the MD5 sum of the final file is correct.
6180c0b0c9ff1b0893a88988c154d94b UCSInstall_UCOS_7.1.3.30000-1.sgn.iso
java
rob.huffman Mon, 06/21/2010 - 08:36
Hi Mike,
I agree with Java (+5 "J")
UCOS_7.1.3.30000-1 would be a "downgrade" from your current version which you said is
@ 7.1.3ES26.32900-26
Release Notes for Cisco Unified Communications
Manager Release 7.1(3b)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713b.pdf
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
mcdonovan Mon, 06/21/2010 - 08:41
Thanks for the quick responses.  My mistake!  I had originally asked for CUC7.1.3ES31.  TAC recommended CUC7.1.3ES33.  The upgrade links they sent me are:
UCSInstall_UCOS_7.1.3.33027-1.sgn.iso_part1of2
UCSInstall_UCOS_7.1.3.33027-1.sgn.iso_part2of2
The TAC engineer told me this is to apply ES33.  I'm looking to verify the MD5 of the combined file.
