SSL VPN license
Jun 21st, 2010
I am trying to configure SSL VPN on a 2911 ISR using Cisco Configuration professional.
Whenever I go to SSL VPN Manager and try to "Create a new SSL VPN" it tells me the license is inactive.
However, when I do a show license in the CLI, it says under feature SSL_VPN the period is lifetime, type is permanent and state is active, not in use.
Any suggestions?
-shawn
Overall Rating: 5 (1 ratings)
Jay Young Fri, 06/25/2010 - 11:49
  • Cisco Employee,
Shawn,
Is SSL_VPN an option under the following command:
license boot module c2900 technology-package SSL_VPN
-Jay
bentoncentral Mon, 06/28/2010 - 03:58
Jay,
It lists 3 possible options and SSL VPN is not one of them.
-shawn
Jay Young Mon, 06/28/2010 - 13:02
  • Cisco Employee,
Shawn,
I am doing a little more research on this.  Would you be able to send me a copy of the "show license" output.  You can always send me a private message if it contains some private info.
I have noticed that there is an issue if the EULA has not been accepted yet to work around that do the following:
Make sure that you have the licence boot configured for securityk9 and from exec prompt try the following:
Router#license modify priority SSL_VPN high
This should then present you with the EULA.  Once you have accepted and got the securityk9 license set for boot, reload and you should now be able to configure webvpn.
-Jay
bentoncentral Tue, 07/13/2010 - 04:48
I think I'm going to stick with routing security is a headache heh.
So I set the priority to high and for some reason it swtiched from licenses to evaluation for the ssl. I set it to medium and it switched back now with a active license.
So I was able to configure it using Ciscp CP. Unfortunately either I'm missing something simple or it won't work in a test environment.
I coult not find a walkthrough with CP only SDM and its too different to follow.
Any good guides or tips? thanks.
Related Content
