ASA V8.3 Upgrade - configuration checker ?
I tried to upgrade my ASA5520 from V8.2 to V8.3 last week and although the log reported no issues
there obviously were  'cos a some of my NAT mappings stopped  completely (!)
I was unabled to complete a fix within my upgrade window so I had to rollback to V8.2.
Is  there any web access to a V8.3 configuration checker / upgrade tool
- there used to be something for IOS configurations ?
[And no, it wasn't a memory issues as I'd upgraded to 2 GB RAM before switching versions]
Many Thanks,
Panos Kampanakis Mon, 06/21/2010 - 11:11
  • Cisco Employee,
I don't think there is a tool for it.
Note there are 2 known issue that could have gone wrong.
1) After the upgrade outside ACL should have been migrated to allow traffic to the real/local server ip addresses instead of the global.
2) If you have overlapping policy nat they could have caused issues.
Can you check if that is the case?
PK
