Multiple SSID for AP in light mode
Answered Question
hello,
I tried to configure an AP which is in light mode to have multiple SSID as I do with autonomous AP but I couldn't, is it possible for an AP in light mode to have multiple SSID? if so, how can I do that?
Thank you in advance for your help.
Correct Answer by Surendra BG about 6 years 11 months ago
irrespective of how many APs we have we can configure 512 WLANs on the WLC, the APs will broadcast only 16 at any time, we need to configure wlan override on the AP or the AP groups to get the desitred WLAN broadcast. regarding the switch port configuration.. the switchport shouls be a simple access port for the perticular vlan so that the AP will get a IP address.. rest all is taken care by the WLC.
supported WLANs is 512 and on the AP you are right its 16..
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52wlan.html
Overall Rating: 5 (2 ratings)
Surendra BG Mon, 06/21/2010 - 10:40
  • Cisco Employee,
light mode means i assume we are using the WLC.. by default all the SSID will get pushed to the AP which is in Light weight mode. and we cannot configue the Light AP.. it will not take the command "config t" at all.. how exactly did we configure the first SSID??
thank you surendra for your quick response,
you are right, we are using wlc, what I tried to ask was that within wlc configuration is it possible to assign multiple ssid to an AP? I see that we only be able to choose one SSID for AP according to the image i'm sending you, but i don't know if i have to perform some other steps before in other to configure multiple ssid.
I hope i was clear and you can help me.
Thank you very much
abersven Mon, 06/21/2010 - 14:21
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Sure you can have multiple SSIDs for lightweight access points. You configure that from the WLC. Create the interfaces first and then the SSIDs you want and assign them to the interfaces. Create multiple WLANs, each WLAN have one WLAN profile and one SSID. You can also assign multiple SSIDs to the same interface or you can have each SSID exiting the WLC on separate dedicated VLANs. I added some snapshots from a lab WLC.
/André
Leo Laohoo Mon, 06/21/2010 - 15:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The WLC can support 1,024 SSID but only 16 SSID is active at any one time.
thank you,
so, if I understood well, I can configure up to 32 AP with 16 different WLAN each AP to be published? or I can publish up to 16 different WLAN no matter how many AP I have?. the other question is, should I configure the switch port to which the AP is connected as trunk port?
thank you very much for your help
Correct Answer
Surendra BG Tue, 06/22/2010 - 09:34
  • Cisco Employee,
Surendra BG Tue, 06/22/2010 - 09:36
  • Cisco Employee,
WLC --------------------------------- SWITCH ---------------------------------- AP
        (trunk allowing all vlans)             (Access for AP to get IP)
Network Admin Thu, 11/20/2014 - 02:50
This single AP will be responsible for multiple SSIDs like for VOICE (vlan 10) and for DATA ( vlan 20 ).In this case, the Switch port that connect to the AP should be TRUNK as well ?
Leo Laohoo Tue, 06/22/2010 - 15:11
  • Hall of Fame,
    2017 LAN, Wireless
Darn it!  I always get this number wrong.    Thanks for the correction.
Related Content
