Integrating CiscoWorks with ACS.
Jun 21st, 2010
Hi, I can’t integrate the CiscoWorks with ACS.
Versions - LMS 3.0 and ACS 4.2.
I reseted the Login Module of the CiscoWorks.
Created a System Identity User in CiscoWorks with all privileges.
Before I change the CiscoWorks to AAA mode, I created a user in the ACS with all privileges.
P.s.: I used the same user and password in the ACS and in the CiscoWorks.
P.s.: The ACS user was created with the “Create New Device Command Set Type” enabled.
I created an AAA client in ACS, changed the CiscoWorks to AAA mode and restarted the Daemon Manager.
But the error message appears:
System Identity User - Not configured properly for cwhp…
Thanks.
