CUPC 7.0 silent install
Answered Question
Jun 21st, 2010
All,
   Hopefully really simple question.  We have finished out beta of CUPC and are ready to begin a limited rollout.  Is there a way to set the cupc .msi package for a silent install.  I have looked around and can't find any procedure for this documented.
Bill
Correct Answer by Jonathan Schulenberg about 6 years 7 months ago
You can't. This information exists in an XML file on the local disk. You will need an MST or a logon script that pre-seeds the default XML file which will be copied when the user launches CUPC. We have covered this before here: https://supportforums.cisco.com/message/3008466#3008466
Overall Rating: 5 (1 ratings)
Jonathan Schulenberg Mon, 06/21/2010 - 12:28
It's a standard MSI so the normal msiexec options should apply. Have you tried using the msiexec /quiet parameter?  Whatever your normal package deployment method is should work for CUPC.
William Maguire Mon, 06/21/2010 - 12:33
Thanks, I had hoped that was the case, but what I was more asking (and not asking really well)
was where in the installer can I give it the name of the presence server
and any other options.
William Maguire Mon, 06/21/2010 - 12:42
Sorry to make you go over old ground but I truly appreciate the fast reply.  This giv
es me a good starting point.
