Is it possible to take the CDR data from a v4.2 Call Manager and copy it to a separate server where it would be made available for reporting?
Answered Question
Jun 21st, 2010
Is it possible to take the CDR data from a v4.2 Call Manager and copy it to a separate server where it would be made available for reporting? We are not interested in migrating the CDR data to v6 because of the concerns it introduces to the upgrade process. Is it possible to get the raw data and somehow serve it from a different machine? (knowing it would be 'old' data that stops as of a certain date). If so, what would be the complexity involved in doing so?
It seems like the CDR data lives within MSSQL and the reporting interface is within the web server portion of the Call Manager... that's as far as we've dug so far.
Correct Answer by Aaron Harrison about 6 years 8 months ago
It is absolutely possible to get the data - anyone you have in your org with basic SQL skills can move the data off to a standalone SQL server. This could be done most simply by backing up and restoring the DB using SQL Enterprise Manager.
Moving the CAR/ART reporting tool would be more difficult... if you do actually use that for reporting (most people find it doesn't do what they need and don't use it for anything but basic troubleshooting, and get a third party package) then the best option may be to keep your publisher (possibly assigning it a new IP) and leave it running for as long as you need reporting.
You would then need a new server to run your upgraded V6 CCM; you may find you need this anyway.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Mon, 06/21/2010 - 13:40
Aaron
