DC/GC Unity5.x
Jun 21st, 2010
Event Type:        Error
Event Source:      CiscoUnity_DSAD
Event Category:    Error
Event ID:          1103
Unity currently is unable to locate a writable Domain Controller, and Unity will not function properly under this configuration. Please re-connect the Unity server to a writable Domain Controller with the DC/GC connection manager.
0x0000054B: The specified domain either does not exist or could not be contacted.
DC/GC shows 2 domains. I setup a manual DC Primary/Secondary on first domain. I don't care about 2nd Domain. How do I get rid of 2nd Domain reference as I keep getting this error message. I am using the latest DC/GC tool.
Overall Rating: 5 (1 ratings)
David Hailey Mon, 06/21/2010 - 17:23
I had a similar issue a while back now.  There was a second AD domain behind a firewall that Unity did not need (nor was it allowed) access to.  However, occasionally during an import of user accounts there would be a reference to this domain in some fashion on a user object.  I would then get the same errors you see now.  I opened a TAC case and was provided some steps to modify the DC/GC Reconnect settings; however, it did not resolve the issue so I inquired about deleting the AD Domain directly within SQL.  I was told this was perfectly viable and would stop Unity from searching for the unwanted domain.  So here's what you do:
Open SQL Server Enterprise Manager > Expand Microsoft SQL Servers > Expand SQL Server Group > Expand Local
Expand Databases > Expand UnityDb > Select Tables
Highlight the ADDomain table, right click and select Open Table > Return All Rows
Select the entry for the AD Domain that Unity is not associated to and select Delete
Please rate helpful posts!
