TTS failover in Cisco VXML Gateway
jondawson Tue, 06/22/2010 - 08:25
You can set the following on the VXML gateway:
ip host tts-
ip host tts--backup < ip address of backup TTS server>
So it would look something like (assuming your local is en-us):
ip host tts-en-us 10.10.10.1
ip host tts-en-us-backup 10.20.10.1
This is shown in deatil in the CVP config and admin guide.
Hope that helps.
JD
rhobab Tue, 10/04/2011 - 04:56
I'm having a problem with this. I am also using the comprehensive model. I have the following relevant config on the gateway.
ip host tts-pt-PT 10.105.37.20
ip host tts-pt-PT-backup 10.101.139.20
ivr tts-server rtsp://tts-pt-PT/synthesizer
Yet when I shutdown the primary TTS Server the gateway is not failing over to the backup TTS server.
What could I be missing?
Victor
rhobab Tue, 10/04/2011 - 05:01
Victor
Related Content
