06-21-2010 07:33 PM - edited 03-04-2019 08:51 AM
Scenario: 2 routers at different locations, there's ip connectivity between them (via MPLS). each router has an Internet connection. 1 link / router routes all Internet traffics, the other is backup. Question: how to route Internet traffics automatically to the backup link / router when the primary is down?
I know IP SLA has monitor ability, but can't figure out how it affects ip routing.
Thanks!
Jon
Solved! Go to Solution.
06-21-2010 11:45 PM
Thanks!
Jon
Hi Jon,
With IP SLA monitor and track command configuration creates the track object and monitors the SLA which is configured in router to mointor a link.
When the icmp request configured with sla fails the primary route is removed and the secondary route with the higher metric becomes the default. The route will be reinstated when the connectivity is restored.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
06-21-2010 11:45 PM
Thanks!
Jon
Hi Jon,
Hope to Help !!
Ganesh.H
06-22-2010 12:18 PM
i figured out same thing at the same time.
thanks Ganesh.H!
