ISR-G2 Router
Answered Question
Jun 21st, 2010
Dear All,
I have a 2921 ISR-G2 router in working condition. I configured the router first time and log out without changing the password and in ISR-G2 it is must to change the password before logging out.
now it is not allowing me to login again.
plaese help me to login again or any password recovery procedure.
Nitin
Correct Answer by Leo Laohoo about 7 years 6 days ago
Password Recovery Procedure for the Cisco 2900 Integrated Services Router
http://www.cisco.com/en/US/products/ps5854/products_password_recovery09186a0080b34901.shtml#procedure
If you can't go into ROMmon:
At the back of the router, on the lower left-hand corner, is where the CF are located.  It's found behind the covers which you can use a small flat-head s crew driver to lift the covers.  Remove one or both of the covers and eject the CF.   Reboot your router and you should be in ROMmon.  Don't forget to insert the CF back.
Don't forget to rate useful posts.  Thanks.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Mon, 06/21/2010 - 22:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Leo Laohoo Mon, 06/21/2010 - 22:47
  • Hall of Fame,
    2017 LAN, Wireless
Happy to provide assistance and thank you very much for the ratings.
