Load balance 2 routers
Jun 22nd, 2010
We have a lease line for our internet using a Cisco 2851.  We are soon to be getting a 2nd line which we would line to use and load balance the lines, how can we do this?  I was thinking of getting a 2nd router and creating a HSRP but wouldn't this then act as active and standby?
Ganesh Hariharan Tue, 06/22/2010 - 03:58
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi Andy,
Check out the below link for load balancing on your router
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Chetan Kumar Ress Tue, 06/22/2010 - 04:09
  • Silver, 250 points or more
Hi Andy
Can you share that currently leased line detail whether it is  T1 or E1, Serial , Ethernet ( Interfaces )
& whether you have plane to take 2nd link from same SP or different SP.
Chetan kumar
Chetan Kumar Ress Tue, 06/22/2010 - 04:33
Hi Andy
For Ethernet , You can do load balancing using routing.
If you SP is agree to run routing protocol then you can use any routing protocol for load balancing. ( Prefer EIGRP)
Or else you can add two default route with same AD.
ip route 0.0.0.0 0.0.0.0 X.X.X.X
Regard
Chetan Kumar
