Nexus 7000 vPC suspended VLAN problem
Jun 22nd, 2010
I am trying to connect a Cat3560G switch to an N7K pair via a vPC.  The VLANs I wish to trunk are being suspended, I am getting the following error messages:
2010 Jun 22 17:03:36 N7K-Core1 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 2,301 on Interface port-channel2 are being suspended. (Reason: Vlan is not allowed on Peer-link)
The VLANs do exist , but a STP instance isnt created for it (I am using RPVST);
N7K-Core1# sh vlan id 2
VLAN Name                             Status    Ports
2    VLAN0002                         active    Po2, Po75
N7K-Core1# sh spanning-tree vlan 2
ERROR: Spanning tree instance(s) for vlan does not exist.
Port       Vlans Err-disabled on Trunk
Eth1/9     none
Eth1/10    none
Eth1/17    2,301
Eth1/18    2,301
Eth1/25    2,301
Eth1/26    2,301
Eth2/2     none
Eth10/1    none
Eth10/2    2,301
Po2        2,301
Po75       2,301
Po99       none
The VLANs are allowed on the trunk (it by default allows all)
interface port-channel1
  description * vPC Peer-Link *
  vpc peer-link
  spanning-tree port type network
I have turned off bridge assurance as a test but no no avail.
Any ideas?
Overall Rating: 5 (5 ratings)
cperkins2 Fri, 08/13/2010 - 13:37
I'm having the same issue between a pair of vPC'd 5020s going to a 6500 using a vPC.
All VLANs which are supposed to go over the trunk/vPC, are showing as err-disable on trunk.  I've checked all configs and they are the same... allowed vlans match on all po interfaces and physical interfaces.
6509:
interface Port-channel78
description Connection to n5020s @ in the MDC
switchport
switchport trunk native vlan 2240
switchport trunk allowed vlan 2002-2006,2010,2014,2018,2022,2024,2026,2240
switchport trunk allowed vlan add 2244,2248,2252,2254,4050,4052,4054
switchport mode trunk
end
N5020-1:
interface port-channel100
  description Uplink to dist01 @ A building
  switchport trunk allowed vlan add 2026,2240,2244,2248,2252,2254,4050
  switchport trunk allowed vlan add 4052,4054
  vpc 100
N5020-2:
  vpc 100
All member ports reflect the correct config.
Both 5020s have the same config for the peer-link:
interface port-channel2
  description VPC Peer-link
  vpc peer-link
Output form 'show interface trunk"
n5020-1# sh int tru
Port          Native  Status        Port
              Vlan                  Channel
Eth1/1        2240    trnk-bndl     Po100
Eth1/2        1       trnk-bndl     Po200
Eth1/17       2240    trnk-bndl     Po78
Eth1/18       2240    trnk-bndl     Po78
Eth1/19       2240    trnk-bndl     Po87
Eth1/20       2240    trnk-bndl     Po87
Po78          2240    trunking      --
Po87          2240    trunking      --
Po100         2240    trunking      --
Po200         1       trunking      --
Port          Vlans Allowed on Trunk
Eth1/1        2002-2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2254,4
050,4052,4054
Eth1/2        180-183
Eth1/17       180-183
Eth1/18       180-183
Eth1/19       2002-2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2254,4
050,4052,4054
Eth1/20       2002-2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2254,4
050,4052,4054
Po78          180-183
Po87          2002-2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2254,4
050,4052,4054
Po100         2002-2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2254,4
050,4052,4054
Po200         180-183
Eth1/1        2002-2004,2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2
254,4050,4052,4054
Eth1/2        180-183
Eth1/17       180-183
Eth1/18       180-183
Eth1/19       2002-2004,2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2
254,4050,4052,4054
Eth1/20       2002-2004,2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2
254,4050,4052,4054
Po78          180-183
Po87          2002-2004,2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2
254,4050,4052,4054
Po100         2002-2004,2006,2010,2014,2018,2022,2024,2026,2240,2244,2248,2252,2
254,4050,4052,4054
Po200         180-183
Port          STP Forwarding
Eth1/1        none
Eth1/2        none
Eth1/17       none
Eth1/18       none
Eth1/19       none
Eth1/20       none
Po78          none
Po87          none
Po100         none
Po200         none
Thank you,
Chris Perkins
INX Inc.
Nicholas Poole Fri, 08/13/2010 - 13:53
You did what I did, omitted the trunk command on the vPC peer-link.  Your config is:
  vpc peer-link
...so add:
cperkins2 Fri, 08/13/2010 - 14:45
Hi - thanks for the quick reply!
I also noticed that running the command "switchport trunk allowed vlan all" told the peer-link to allow all vlans.  I didn't see it doing that by default... ?
Also, I changed the port-type to "normal" for the spanning-tree config.  I had an issue with one of the downstream devices wanting to be STP root for some VLANs... I changed the peer-links to "spanning-tree port type normal" and that solved the problem of the 5010 wanting to be root instead of our 6509 upstream.
Chris
Radium Fu Tue, 08/21/2012 - 15:55
Answer
  vpc peer-link
You do need one more command. to turn peer link as trunk. otherwise it will not transfer any vlan through Peer-link
"switchport mode trunk"
Jarvin Christia... Wed, 01/30/2013 - 17:58
I got the same issue but the difference is the configuration is in fabricpath.
  switchport
  switchport mode fabricpath
  vpc peer-link
%ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 971 on Interface port-channel1 are being suspended. (Reason: Vlan is not allowed on Peer-link)
Vinod Kumar Tue, 01/13/2015 - 11:02
We have some issues with creating new vlans on the N7K switches. This is due to a bug (CSCtr08143) on the current software version we are running.
The permanent fix is to upgrade the switches to new version as we are running a really old code but there is a simple workaround that resolves the issue if you see it..
Here is the workaround:
-Create vlan on both switches
-Confirm that both switches have vlan created by using command ‘show vlan’ or ‘show vlan id xxxx
-Perform a ‘no spanning-tree vlan xxxx
-Then perform ‘spanning-tree vlan xxxx
-Use ‘show spanning-tree vlan xxxx’ to see if the vlan has now been created and if forwarding
Cheers!!
Vinod
Vinod Kumar Tue, 01/13/2015 - 10:58
Cheers!!
Vinod
msmith508 Mon, 04/04/2016 - 12:29
NEVER disable spanning tree on a production switch!
You will create a loop!
If you create a loop you may need to reboot the switch in order to recover from it!
vikasmandhan Tue, 05/17/2016 - 03:56
What version has this issue ? I'm having the same issue while creating a new VLAN. it's showing suspend.
Jarvin Christia... Mon, 03/02/2015 - 23:34
Just want to ask if you have included the "peer-switch" configuration under vpc? I think both vPC Peers should have the same STP priority (per vlan) on both N7K1 and N7K2. Please see attached power point file. Hope this will help.
Cheers,
Jarvin
scneima01 Mon, 06/27/2016 - 15:09
HA! 6 years ago. I'll post my feedback anyway since my solution doesn't seem to be here and I keep running into this problem.
I did...
vlan blah
shut
!then
vlan blah
no shut
Badabing! Looks like vpc or something needed a little refresh and that was enough to get the switch to check again.
sanders.ryan Mon, 08/15/2016 - 12:21
I ran into same exact problem...  Everything on the interface needs to match exactly to the other interfaces. I was missing the below from the edge switch side.
interface TenGigabitThernet1/0/1
 description vpc 1015
 switchport trunk native vlan xx
 switchport trunk allowed vlan x,x,x,x
 switchport nonegotiate
 spanning-tree link-type point-to-point
 channel-group 1 mode active
interface TenGigabitThernet1/0/2
 ip dhcp snooping trust  <<<<<<< This is what I was missing on the te1/0/1 interface which caused it
                                                              to go into "suspended" Once I added it came right up.
