Many CRC errors on Radio Interface of BR1310
Jun 22nd, 2010
we do have a pair of AIR-BR1310 connected together at about -55dBm. Everything looks fine but if we are transmitting data over this link we can see crc errors rising up quickly on the radio interface of one of the bridges. On the other side there is no such behaviour.
Does anybody know what could be a reason for a large amount of crc errors on one radio interface?
Thanks in advance
abersven Tue, 06/22/2010 - 15:51
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
RSSI at -55 is good. But you should also check SNR to see how much stronger this signal is compared to the background noise.
/André
g.anders Wed, 06/23/2010 - 04:00
Hi Andre,
many thanks. We have done the Carrier Noise Test and than selected the least congested channel (appr. 5%). So I think this should be ok.
Could it be a failure within the radio interfece itself?
Thanks and regards
Gundolf.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
