Asa as VPN concetrator and Avaya Hardphones with VPN RAS
Jun 22nd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
The issue is as follows;
Roughly the following happens
1.    Steady situation, 4 phone connected, all having an IP assigned from the local IP pool
2.    A phone (lets say #1) gets disconnected (reason is not that important), with local IP pool IP#1
3.    IP#1 now goes to phone #2
4.    – here it gets a little unclear whether IP#2 also starts to “travel around”, or this ‘traveling’ only happens for IP#1 –
5.    After while phone #1 comes back  but IP#1 still ‘travels’ around
6.    After a period of instability everything returns to a steady state and at least one of the previously assigned IP’s is released and the phone gets another IP from the pool
During the instability the VoIP server actually sees the IP’s being swapped but for an unknown reason (whether that is caused by the ‘speed’ of change or something else) one IP form the local pool (from a VoIP server perspective) is bound to multiple phone numbers, causing no call can be made or calls in progress get disrupted.
The issue can easily be re-produced by disconnection one phone (regardless which one)
Have you seen such behavior before? I wonder if this is a bug in Asa version or that it might have to do with the fact that one UserID/PWD is used for multiple connections. Any thoughts?
Marcin Latosiewicz Tue, 06/22/2010 - 07:55
  • Cisco Employee,
Since this is local IP address assignment... do you use reuse?
Do the phones remember the IP address they had prior to disconnect? Do they request new address in mode config and is the address send by the ASA and applied?
Can you try what would happen with assignment from either AAA or DHCP? Same or different behavior?
KAI FALKENBERG Wed, 06/23/2010 - 04:33
I haven’t seen that option.
I don’t understand the nature of this question. What has this to do with the fact that if VPN#1 with local pool IP#1 disconnects (for whatever reason), IP#1 starts to move around over the remaining VPN tunnels that already have another local pool IP-address assigned in the first place.
This is something that needs to checked, but will require some effort. AAA can be ‘simulated’ I think, by using multiple UID’s (versus the one currently in place).
Can you please verify that the single username and password do not cause this issue?
Marcin Latosiewicz Wed, 06/23/2010 - 09:00
  • Cisco Employee,
Kai,
Please elaborate on what you mean by traveling and "moving around".
I think problem is we're trying to use two different vocabularies to describe the problem.
Esentially a HW vpn client should request an IP address in mode config of IPsec.
IPAA coponent tries to allocate that IP address for client and returns it ideally to IPsec.
IPsec then allocates a proxy ID of: IP_ADDRESS_RECEIVED to "ANY" (by default, not counting split tunneling etc).
Once all IPsec sessions torn down (isakmp keepalives should take care of it) we should also eventually return the IP address back to pool.
KAI FALKENBERG Thu, 06/24/2010 - 06:55
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Ok, this is what I mean with ‘traveling / moving around’
Time X, steady situation
VPN #1 – Local IP pool assignment=IP #1
VPN #2 – Local IP pool assignment=IP #2
VPN #3 – Local IP pool assignment=IP #3
VPN #4 – Local IP pool assignment=IP #4
Now VPN #1 gets disconnected, and what happens is this:
VPN #2 – Local IP pool assignment=IP #1
A very short moment later
VPN #3 – Local IP pool assignment=IP #1
Yet another short moment later
VPN #4 – Local IP pool assignment=IP #1
(if VPN#1 doesn’t reconnect it goes steady again after some period of time, I can’t tell approx how long that takes)
When VPN#1 reconnects within 2 to 3 minutes the above keeps on going for approx 1 minute or so and then it goes steady again but with that change at least one IP is changed, something like this:
VPN #2 – Local IP pool assignment=IP #5
This is what I mean with IP’s traveling/moving around. Please note that the phone notices this IP change and re-register with the ‘new’ IP (which they have for only a very short period of time, a second or less).
Kai
Marcin Latosiewicz Thu, 06/24/2010 - 07:25
  • Cisco Employee,
Kai,
Phones should not re-request IP address while phase 1 and phase 2 are up - it would require those sessions to to be completly re-established.
Can you please attach:
show run crypto
show run tunnel-grou
show run group-policy
and tell me which tunnel-group you're using:
show vpn-sessiondb det would also share some more info
KAI FALKENBERG Wed, 06/30/2010 - 02:48
show run crypto
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 20 set pfs
crypto dynamic-map Outside_dyn_map 20 set transform-set ESP-AES-128-SHA
crypto dynamic-map Outside_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 40 set pfs
crypto dynamic-map Outside_dyn_map 40 set transform-set ESP-AES-128-SHA
crypto dynamic-map Outside_dyn_map 40 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 40 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 60 set pfs
crypto dynamic-map Outside_dyn_map 60 set transform-set ESP-AES-128-SHA
crypto dynamic-map Outside_dyn_map 60 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 60 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 80 set pfs
crypto dynamic-map Outside_dyn_map 80 set transform-set ESP-AES-128-SHA
crypto dynamic-map Outside_dyn_map 80 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 80 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 100 set pfs
crypto dynamic-map Outside_dyn_map 100 set transform-set ESP-3DES-SHA
crypto dynamic-map Outside_dyn_map 100 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 100 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 120 set pfs
crypto dynamic-map Outside_dyn_map 120 set transform-set ESP-AES-128-SHA
crypto dynamic-map Outside_dyn_map 120 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 120 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 140 set pfs
crypto dynamic-map Outside_dyn_map 140 set transform-set ESP-AES-128-SHA
crypto dynamic-map Outside_dyn_map 140 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 140 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 160 set pfs
crypto dynamic-map Outside_dyn_map 160 set transform-set ESP-AES-128-SHA
crypto dynamic-map Outside_dyn_map 160 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 160 set security-association lifetime kilobytes 4608000
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map interface outside
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp policy 1
authentication rsa-sig
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 70
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
show run tunnel-group
tunnel-group DefaultRAGroup general-attributes
address-pool (inside) vpnphone-ip-pool
address-pool vpnphone-ip-pool
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication (outside) none
tunnel-group VPNPHONE type remote-access
tunnel-group VPNPHONE general-attributes
default-group-policy VPNPHONE
tunnel-group VPNPHONE ipsec-attributes
pre-shared-key *
group-policy DfltGrpPolicy attributes
vpn-idle-timeout 3
webvpn
  svc keepalive none
  svc dpd-interval client none
  svc dpd-interval gateway none
  customization value DfltCustomization
group-policy VPNPHONE internal
group-policy VPNPHONE attributes
vpn-tunnel-protocol IPSec
Active Session Summary
Sessions:
                           Active : Cumulative : Peak Concurrent : Inactive
  SSL VPN               :       0 :          0 :               0
    Clientless only     :       0 :          0 :               0
    With client         :       0 :          0 :               0 :        0
  Email Proxy           :       0 :          0 :               0
  IPsec LAN-to-LAN      :       0 :          0 :               0
  IPsec Remote Access   :       3 :       9477 :               5
  Totals                :       3 :       9477
License Information:
  IPsec   :    250    Configured :    250    Active :      3    Load :   1%
  SSL VPN :    100    Configured :    100    Active :      0    Load :   0%
  IPsec               :          3 :      16940 :               7
  SSL VPN             :          0 :          0 :               0
    AnyConnect Mobile :          0 :          0 :               0
    Linksys Phone     :          0 :          0 :               0
  Totals              :          3 :      16940
Tunnels:
  IKE    :          3 :       9477 :               5
  IPsec  :          3 :       9182 :               5
  Totals :          6 :      18659
Active NAC Sessions:
  No NAC sessions to display
Active VLAN Mapping Sessions:
  No VLAN Mapping sessions to display
Marcin Latosiewicz Wed, 06/30/2010 - 08:40
  • Cisco Employee,
Kai,
Some questions:
1.) Why all those entries in dynamic crypto map? I would say put multiple transofrmsets together rather then specifiging them one by one under different entries.
2.) What is the netmask you put on the ip local pool command /24 or /32?
3.) Can you get "show vpn-sessiondb det remote" during working and "traveling" situation?
4.) Nat traversal turned off?
Marcin
KAI FALKENBERG Thu, 07/01/2010 - 05:02
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
1. would that make a difference?
2. ip local pool vpnphone-ip-pool 10.82.186.11-10.82.187.254 mask 255.255.254.0
3. show vpn-sessiondb det remote
Session Type: IPsec Detailed
Username     : Ge34rfd                Index        : 16942
Assigned IP  : 10.82.187.206          Public IP    : 94.209.208.40
Protocol     : IKE IPsec
License      : IPsec
Encryption   : 3DES AES128            Hashing      : MD5 SHA1
Bytes Tx     : 114424                 Bytes Rx     : 59704
Pkts Tx      : 2065                   Pkts Rx      : 1380
Pkts Tx Drop : 0                      Pkts Rx Drop : 0
Group Policy : VPNPHONE               Tunnel Group : VPNPHONE
Login Time   : 06:20:22 UTC Thu Jul 1 2010
Duration     : 4h:14m:50s
NAC Result   : Unknown
VLAN Mapping : N/A                    VLAN         : none
IKE Tunnels: 1
IPsec Tunnels: 1
IKE:
  Tunnel ID    : 16942.1
  UDP Src Port : 2070                   UDP Dst Port : 500
  IKE Neg Mode : Aggressive             Auth Mode    : preSharedKeys
  Encryption   : 3DES                   Hashing      : MD5
  Rekey Int (T): 86400 Seconds          Rekey Left(T): 71113 Seconds
  D/H Group    : 2
  Filter Name  :
IPsec:
  Tunnel ID    : 16942.2
  Local Addr   : 0.0.0.0/0.0.0.0/0/0
  Remote Addr  : 10.82.187.206/255.255.255.255/0/0
  Encryption   : AES128                 Hashing      : SHA1
  Encapsulation: Tunnel                 PFS Group    : 2
  Rekey Int (T): 28800 Seconds          Rekey Left(T): 13513 Seconds
  Idle Time Out: 3 Minutes              Idle TO Left : 2 Minutes
NAC:
  Reval Int (T): 0 Seconds              Reval Left(T): 0 Seconds
  SQ Int (T)   : 0 Seconds              EoU Age(T)   : 15288 Seconds
  Hold Left (T): 0 Seconds              Posture Token:
  Redirect URL :
Username     : Ge34rfd                Index        : 16943
Assigned IP  : 10.82.187.207          Public IP    : 83.163.175.230
License      : IPsec
Bytes Tx     : 29510300               Bytes Rx     : 29375072
Pkts Tx      : 108361                 Pkts Rx      : 107003
Login Time   : 07:08:42 UTC Thu Jul 1 2010
Duration     : 3h:26m:31s
IKE Tunnels: 1
IPsec Tunnels: 1
IKE:
  Tunnel ID    : 16943.1
  UDP Src Port : 500                    UDP Dst Port : 500
  Rekey Int (T): 86400 Seconds          Rekey Left(T): 74011 Seconds
  D/H Group    : 2
  Filter Name  :
IPsec:
  Tunnel ID    : 16943.2
  Remote Addr  : 10.82.187.207/255.255.255.255/0/0
  Rekey Int (T): 28800 Seconds          Rekey Left(T): 16412 Seconds
  Idle Time Out: 3 Minutes              Idle TO Left : 3 Minutes
  Bytes Tx     : 29520940               Bytes Rx     : 29385880
  Pkts Tx      : 108399                 Pkts Rx      : 107042
NAC:
  SQ Int (T)   : 0 Seconds              EoU Age(T)   : 12389 Seconds
  Redirect URL :
4. again would that cause the described effect?
Marcin Latosiewicz Thu, 07/01/2010 - 06:23
  • Cisco Employee,
Kai,
Please configure reuse delay of let's day 60 minutes...
vpn-addr-assign local reuse-delay 60
This should prohibit the clients to use same IP address for at least 60 minutes.
Regarding outputs... same user connecting from different IP addresses?
Marcin
