100mb link between two offices
hi,
   one of my client wants two of his office connected via a 100mb link from Service Provider. These offices are accross the road. his company policy doesnt allow him to terminate the link on any switch , he needs a dedicated router for this. my qestion is what router i can suggest on  which a 100mb link can be terminated without any performance issue ?
regards
Neo
Giuseppe Larosa Tue, 06/22/2010 - 05:43
  • Hall of Fame,
    Founding Member
Hello Neo,
if the offices are close
you should consider to have two fiber pairs installed
However, using a router without performance penalties means going up to C3845 or more
Consider that SW based routers performances are dependent on features : the more features are enabled (ACLs, QoS and so on) the less performance you get
see attached file
it gives you raw performance undirectional (you need to divide by two)
if you have multilayer switches you should consider deploying the fiber across the road, by the way you cannot intercept a fiber ( no radio waves) so security should be fine.
Hope to help
Giuseppe
Leo Laohoo Tue, 06/22/2010 - 15:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It means that if you enable CEF, packets are pushed faster.  It's true that the 3845 can push up to 256 Mbps of UN-ENCRYPTED traffic (cut 50% if you want to encrypt).
However, this is a very "expensive" option.  The most effective and efficient, if both sites are just across the road from one another, is to run a multi-core/multi-pair fibre optic link.  Using fibre optic, not only do you get security but the added benefit of running CWDM/DWDM turning one fibre pair to plenty.  Another benefit is speed:  10/100/1Gb/10Gb Mbps
Propose this to your boss.  It might give you either a raise or a promotion.
