The outside sub-network is not accesssible
Jun 22nd, 2010
I have ASA 5505 with Secplus - configured and  working fine but I have a lame problem.
The situation - I have LAN  Internet provider ( the IPs are for example ):
ASA IP - 1.1.1.3/27 -  default GW 1.1.1.2/27 ( Internet, IPSec working like charm )
I have  second machine ( linux router ) attached to the same LAN  network but in different location with IP 1.1.1.4/27 (same d.gw) -  again, working like charm
The issue - the linux box and the ASA are  not accessible from each other.
After several experiments - I found  working IP 1.1.1.5/27 in this subnet which is pinglable from the linux  box but not from the ASA ( icmp is allowed in my conf. )
Can somebody  help?
gatlin007 Tue, 06/22/2010 - 07:26
  • Silver, 250 points or more
Can the linux box and the ASA properly ARP each other?  For example does a ‘show arp’ on the ASA resolve the correct MAC address to the IP address of the linux box?  On the linux box does an ‘arp –a’ resolve the correct MAC address to the IP address of the ASA?
Chris
andrew_hack Tue, 06/22/2010 - 07:36
Chris,
No, I just tried to ping the both machines from each other and the MAC addresses not appears.
On the linux box I can see:
asa-host (1.1.1.3) at on eth0
from ASA side nothings is shown in the arp table.
gatlin007 Tue, 06/22/2010 - 07:41
Andrey,
Based on that I’d troubleshoot with your service provider as to why ARP requests/responses aren’t passing between the two sites.
Chris
andrew_hack Tue, 06/22/2010 - 07:45
Thank you very much for this good advise - I will post any development.
andrew_hack Wed, 06/23/2010 - 03:04
Chris,
The provider state that the problem is not in his configuration - as is expected.
Anyway..... Can I diagnose the problem in different way? What I can do from my side?
Hitesh Vinzoda Wed, 06/23/2010 - 04:06
Try adding static arp entries in both the devices for each other
Hitesh Vinzoda
Pls rate useful posts
gatlin007 Thu, 06/24/2010 - 07:12
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Andrey,
Is this what your topology looks like?
If so has your service provider indicated they support customer hosts communicating with each other over the service provider switch fabric?  If they do support this than one thing you can do is use a packet analyzer such as wireshark to demonstrate the problem.  On the ASA you can use the built in packet capture utility.
This article has good advice on troubleshooting an ASA and covers packet capture.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807c35e7.shtml#s3
Capture a successful ARP request/response between the ASA and the Default Gateway.  Capture an unsuccessful ARP request/response between the ASA and the Linux host.  Assemble the evidence and send it to your service provider.  If you reside in a free market society and the service provider has a listening problem consider a new service provider.
Chris
andrew_hack Sat, 06/26/2010 - 02:28
Chris,
Yes, the topology is similar - with comment from my side - I don't how many and what type of switches stays between the both hosts.
I will play with the packet capture and will see what will be the result.
In addition:
I found another working the IP in the same subnet - which is pingable from the Linux box but not from the ASA.
Do you thing that the problem can reside on the ASA side - by default ASA come with everything denied and I try to stick to this policy. The allowed services are based on my needs. Please, check my configuration below.
ASA configuration:
: Saved
ASA Version 8.2(1)
terminal width 160
hostname gw
domain-name karadimov.info
enable password ************************ encrypted
passwd **************************** encrypted
names
interface Vlan1
nameif inside
security-level 90
ip address 192.168.5.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 1.1.1.3 255.255.255.224
interface Vlan3
nameif outside_1
security-level 0
pppoe client vpdn group spnet
ip address pppoe
interface Vlan100
nameif internal-users
security-level 100
ip address 192.168.6.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
switchport protected
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
switchport trunk allowed vlan 1
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 100
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone EEST 2
clock summer-time EEDT recurring last Sun Mar 3:00 last Sun Oct 4:00
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server ?.?.?.?
name-server ?.?.?.?
name-server ?.?.?.?
same-security-traffic permit intra-interface
access-list 24101 extended permit icmp any any echo
access-list 24101 extended permit icmp any any echo-reply
access-list 24101 extended permit icmp any any source-quench
access-list 24101 extended permit icmp any any unreachable
access-list 24101 extended permit icmp any any time-exceeded
access-list 24101 extended permit ah any any
access-list 24101 extended permit esp any any
access-list outside_1_access_in extended permit icmp any any echo
access-list outside_1_access_in extended permit icmp any any echo-reply
access-list outside_1_access_in extended permit icmp any any source-quench
access-list outside_1_access_in extended permit icmp any any unreachable
access-list outside_1_access_in extended permit icmp any any time-exceeded
access-list outside_1_access_in extended permit ah any any
access-list outside_1_access_in extended permit esp any any
access-list outside_cryptomap extended permit ip host 192.168.5.64 10.0.0.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip host 192.168.5.64 10.0.0.0 255.255.255.0
pager lines 24
logging enable
logging history critical
logging asdm warnings
logging mail critical
no logging message 106023
mtu inside 1500
mtu outside 1500
mtu outside_1 1492
mtu internal-users 1500
no failover
icmp unreachable rate-limit 10 burst-size 5
icmp permit any inside
icmp permit any internal-users
no asdm history enable
arp outside 1.1.1.99 0026.cb32.6650 alias
arp timeout 14400
global (outside) 1 interface
global (outside_1) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (internal-users) 1 0.0.0.0 0.0.0.0
static (inside,outside) 1.1.1.99 192.168.5.61 netmask 255.255.255.255
access-group 24101 in interface outside
access-group outside_1_access_in in interface outside_1
route outside 0.0.0.0 0.0.0.0 1.1.1.2 1 track 1
route outside 10.0.0.0 255.255.255.0 85.130.93.33 1 track 2
route outside_1 0.0.0.0 0.0.0.0 2.2.2.3 2
route outside_1 10.0.0.0 255.255.255.0 2.2.2.3 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.5.0 255.255.255.0 inside
http 192.168.6.0 255.255.255.0 internal-users
sysopt noproxyarp inside
sysopt noproxyarp internal-users
sla monitor 123
type echo protocol ipIcmpEcho 1.1.1.3 interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map6 1 match address outside_cryptomap
crypto map outside_map6 1 set peer ?.?.?.?
crypto map outside_map6 1 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map6 1 set security-association lifetime seconds 86400
crypto map outside_map6 interface outside
crypto map outside_1_map1 1 match address outside_1_cryptomap
crypto map outside_1_map1 1 set peer ?.?.?.?
crypto map outside_1_map1 1 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_1_map1 1 set security-association lifetime seconds 86400
crypto map outside_1_map1 interface outside_1
crypto isakmp enable outside
crypto isakmp enable outside_1
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
track 1 rtr 123 reachability
telnet timeout 5
ssh 192.168.5.0 255.255.255.0 inside
ssh 192.168.6.0 255.255.255.0 internal-users
ssh timeout 60
ssh version 2
console timeout 0
vpdn group spnet request dialout pppoe
vpdn group spnet localname andros
vpdn group spnet ppp authentication pap
vpdn username andros password *********
priority-queue outside
priority-queue outside_1
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
tunnel-group ?.?.?.? type ipsec-l2l
tunnel-group ?.?.?.? ipsec-attributes
pre-shared-key *
tunnel-group ?.?.?.?_1 type ipsec-l2l
tunnel-group ?.?.?.?_1 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
smtp-server 192.168.5.253
prompt hostname context
Cryptochecksum:fdeb155f6e834b253d5f2ee8b8e035d0
: end
gatlin007 Sat, 06/26/2010 - 10:54
Andrey,
Be sure to verify with your service provider that they support the functionally you are troubleshooting.
By default ARP works on the ASA.
I don’t see anything in your ASA config that would prevent ARP from working.  Focus on the ASA and Linux host ability to resolve IP addresses to MAC addresses.  Once ARP works as expected then pursue other possible blocking problems if they persist.
Chris
