Get Information CallManager
Answered Question
Jun 22nd, 2010
Good Morning,
I will like know, if exist tutorial or some help about how I do for get informations in call manager ex: ID, duration, source number, etc... with my system, exist some configuration for direction of information in my table?
Thanks everyone!
Correct Answer by William Bell about 6 years 11 months ago
If I follow, I think you are looking for a data dictionary.  The one you need will depend on which version of CUCM you are working with.  You can get data dictionaries for all versions of CUCM starting with 5x here:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
For example, the data dictionary for CUCM 7.1.3:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/datadict/7_1_3/datadictionary_713.pdf
HTH.
Bill
Please remember to rate helpful posts.
Correct Answer by Jaime Valencia about 6 years 11 months ago
Information is quite vague. You need to be more specific.
I believe you're asking for CALL information?
If so:
Cisco Unified Communications Manager Call Detail  Records Administration Guide, Release 8.0(2)
Otherwise you'll need to elaborate.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Tue, 06/22/2010 - 06:53
  • Cisco Employee,
  • Hall of Fame,
    2011
If so:
java
fernandocorinthiano Tue, 06/22/2010 - 07:44
Hi Javalenc,
the link than you give me is very good and very important too...
What I need, is know how I can send information of call manager cisco for a table (SqlServer) of my system of call control voip
My system today already get information of a call manager Asterisk, and in asterisk exist a window where I configure what is the database, fields than will get information of calls, with number source, duration call, cost and others
thank you very much
Correct Answer
William Bell Tue, 06/22/2010 - 08:31
  • Purple, 4500 points or more
HTH.
Bill
