Giuseppe Larosa Tue, 06/22/2010 - 10:14
  • Hall of Fame,
    Founding Member
Hello Inderdeep,
the idea behind GMPLS is to use MPLS signalling plane to as the signalling plane in an optical network where different wavelenghts are used to create all optical switched paths.
So the first level LSP is implemented in such a way that the label is mapped to a specific wavelength and this means it  reaches a specific router connected to the optical cloud.
well generalized stands for total separation of control plane and forwarding plane.
http://www.javvin.com/protocolGMPLS.html
Hope to help
Giuseppe
inderdeeps Tue, 06/22/2010 - 11:14
Hello Giuslar,
Thanxs for your valuable notes on it.
I need how Gmpls signalling merge ? as what i got from the concept that Router and Optical devices have same signals and so that
The standard would create  a single control plane that extends from IP at Layer 3 right down to the optical  transport level at Layer 1.
It means that router and optical devices have knowledge to forward the packets and they can share the topology as usual as router sharing it with another router?
With Regards
Inderdeep
Giuseppe Larosa Wed, 06/23/2010 - 00:08
  • Hall of Fame,
    Founding Member
Hello Inderdeep,
the router is the brain and the optical device or whatever  is the arm.
In the first days of MPLS deployed over ATM it was the same with a C7200 or routing engine used as brain for an ATM switch.
The target is to avoid too many levels if an MPLS label means a specific lambda = going to a specific remote PE on the edge of the optical cloud  in case of fault the routing protocol will tell to the node you now need to send traffic to remote PEy using lambda2.
otherwise in case of fault  each layer would try to react to faults in some cases doing opposite things
Hope to help
Giuseppe
inderdeeps Sun, 07/04/2010 - 02:21
Hi giuslar,
Thanxs for giving your views on GMPLS.
Cheers!!!
Inderdeep
