Archive backups issue in VSOM
cacravero
Hi everyone
I'm having an issue with the archives backups in my system.
I have 50 branches running the Cisco Video Surveillance Solution. Each branch has cameras, two media server, one is a primary and other the secondary, and a 3560 PoE switch that connect cameras, servers to the customer network cloud. Branches are connected through MPLS cloud.
Also I have a primary VSOM that manage all this servers, cameras, view, etc.
I have all running archives configured to do a backup in the secondary media server backup but the backups were not performed.
Secondary Media Server has the backup repository checked and the archives are configured to do a backup at 1 am. Secondary Media Server is configured as backup server at VSOM.
Does anyone saw this issue, have an idea how can resolve this?
slaanoi
Cacravero,
Keep in mind that VSM backups occur only once every 24hrs at the time you indicate. Select one of the archives manually configured for backup and check the Backup tab to see the status and log in the details section. What output do you have?
SL.
I configured one archive to make a backup in a Backup Server at 1 am. I wait 24 hr and check the backup tab in the archive view, there isn't  record of the archived files.
I also have a TAC case opened for this, Cisco told me that the problem is the amount of servers and cameras running in a 1RU VSOM, but, if this is true, then they made mistakes in the system design phase.
I'm having the same issue. I created the backup server and set my archives to backup but no backup is present. Here's the log.
a_p_s1_CASH_Room_1203_1_-_a_Cashier_room_1203__23
Status:Succeeded
Start Time:2010-11-21 00:00:01
End Time:2010-11-21 00:00:03
Log:
Job started at Sun Nov 21 00:00:01  2010
Processing job for archive:  a_p_s1_CASH_Room_1203_1_-_a_Cashier_room_1203__23
Backup Name:  a_s_10_187_16_10_a_p_s1_CASH_Room_1203_1_-_a_Cashier_room_1203__23_bk
Remote  Host: 10.187.16.11
Archive Start Time: Fri Nov 19 02:47:41  2010
Archive End Time: Ongoing
Backup Period (after archive start/end time  and last backup file time filtering):
Sat Nov 20 00:00:00 2010
Sat Nov 20  11:59:00 2010
Found file entry /media0/1008/media_master size  248
Found file entry /media0/1008/20101120/4ce7786d.smd size  29851568
Found file entry /media0/1008/20101120/4ce77999.smd size  29864543
Found file entry /media0/1008/20101120/4ce77ac5.smd size  29850417
Found file entry /media0/1008/20101120/4ce77bf1.smd size  29868132
Found file entry /media0/1008/20101120/4ce77d1d.smd size  29861820
Found file entry /media0/1008/20101120/4ce77e49.smd size  29850363
Found file entry /media0/1008/20101120/4ce77f75.smd size  29863988
Found file entry /media0/1008/20101120/4ce780a1.smd size  29858058
Found file entry /media0/1008/20101120/4ce781cd.smd size  29862471
Found file entry /media0/1008/20101120/4ce782f9.smd size  29861375
Found file entry /media0/1008/20101120/4ce78425.smd size  29852042
Found file entry /media0/1008/20101120/4ce78551.smd size  29872984
Found file entry /media0/1008/20101120/4ce7867d.smd size  29855381
Found file entry /media0/1008/20101120/4ce787a9.smd size  29860420
Found file entry /media0/1008/20101120/4ce788d5.smd size  29848066
Found file entry /media0/1008/20101120/4ce78a01.smd size  29870177
Found file entry /media0/1008/20101120/4ce78b2d.smd size  29855540
Found file entry /media0/1008/20101120/4ce78c59.smd size  29856706
Found file entry /media0/1008/20101120/4ce78d85.smd size  29860203
Found file entry /media0/1008/20101120/4ce78eb1.smd size  29855456
Found file entry /media0/1008/20101120/4ce78fdd.smd size  29859558
Found file entry /media0/1008/20101120/4ce79109.smd size  29858341
Found file entry /media0/1008/20101120/4ce79235.smd size  29859636
Found file entry /media0/1008/20101120/4ce79361.smd size  29855801
Found file entry /media0/1008/20101120/4ce7948d.smd size  29859871
Found file entry /media0/1008/20101120/4ce795b9.smd size  29868591
Found file entry /media0/1008/20101120/4ce796e5.smd size  29852141
Found file entry /media0/1008/20101120/4ce79811.smd size  29854983
Found file entry /media0/1008/20101120/4ce7993d.smd size  29862022
Found file entry /media0/1008/20101120/4ce79a69.smd size  29858748
Found file entry /media0/1008/20101120/4ce79b95.smd size  29861478
Found file entry /media0/1008/20101120/4ce79cc1.smd size  29862144
Found file entry /media0/1008/20101120/4ce79ded.smd size  29859994
Found file entry /media0/1008/20101120/4ce79f19.smd size  29854923
Found file entry /media0/1008/20101120/4ce7a045.smd size  29856251
Found file entry /media0/1008/20101120/4ce7a171.smd size  29862814
Found file entry /media0/1008/20101120/4ce7a29d.smd size  29854954
Found file entry /media0/1008/20101120/4ce7a3c9.smd size  29856526
Found file entry /media0/1008/20101120/4ce7a4f5.smd size  29877573
Found file entry /media0/1008/20101120/4ce7a621.smd size  29851202
Found file entry /media0/1008/20101120/4ce7a74d.smd size  29856379
Found file entry /media0/1008/20101120/4ce7a879.smd size  29863374
Found file entry /media0/1008/20101120/4ce7a9a5.smd size  29852742
Found file entry /media0/1008/20101120/4ce7aad1.smd size  29865430
Found file entry /media0/1008/20101120/4ce7abfd.smd size  29846631
Found file entry /media0/1008/20101120/4ce7ad29.smd size  29869545
Found file entry /media0/1008/20101120/4ce7ae55.smd size  29855729
Found file entry /media0/1008/20101120/4ce7af81.smd size  29855904
Found file entry /media0/1008/20101120/4ce7b0ad.smd size  29861688
Found file entry /media0/1008/20101120/4ce7b1d9.smd size  29853942
Found file entry /media0/1008/20101120/4ce7b305.smd size  29861823
Found file entry /media0/1008/20101120/4ce7b431.smd size  29858155
Found file entry /media0/1008/20101120/4ce7b55d.smd size  29864927
Found file entry /media0/1008/20101120/4ce7b689.smd size  29853695
Found file entry /media0/1008/20101120/4ce7b7b5.smd size  29863339
Found file entry /media0/1008/20101120/4ce7b8e1.smd size  29852069
Found file entry /media0/1008/20101120/4ce7ba0d.smd size  29864755
Found file entry /media0/1008/20101120/4ce7bb39.smd size  29864065
Found file entry /media0/1008/20101120/4ce7bc65.smd size  29848405
Found file entry /media0/1008/20101120/4ce7bd91.smd size  29858457
Found file entry /media0/1008/20101120/4ce7bebd.smd size  29866372
Found file entry /media0/1008/20101120/4ce7bfe9.smd size  29858038
Found file entry /media0/1008/20101120/4ce7c115.smd size  29857027
Found file entry /media0/1008/20101120/4ce7c241.smd size  29860109
Found file entry /media0/1008/20101120/4ce7c36d.smd size  29852255
Found file entry /media0/1008/20101120/4ce7c499.smd size  29876492
Found file entry /media0/1008/20101120/4ce7c5c5.smd size  29853492
Found file entry /media0/1008/20101120/4ce7c6f1.smd size  29856849
Found file entry /media0/1008/20101120/4ce7c81d.smd size  29864255
Found file entry /media0/1008/20101120/4ce7c949.smd size  29852441
Found file entry /media0/1008/20101120/4ce7ca75.smd size  29857673
Found file entry /media0/1008/20101120/4ce7cba1.smd size  29862692
Found file entry /media0/1008/20101120/4ce7cccd.smd size  29853155
Found file entry /media0/1008/20101120/4ce77165.smd size  29862715
Found file entry /media0/1008/20101120/4ce7cdf9.smd size  29863428
Found file entry /media0/1008/20101120/4ce77291.smd size  29858338
Found file entry /media0/1008/20101120/4ce7cf25.smd size  29853330
Found file entry /media0/1008/20101120/4ce773bd.smd size  29859320
Found file entry /media0/1008/20101120/4ce7d051.smd size  29864165
Found file entry /media0/1008/20101120/4ce774e9.smd size  29861360
Found file entry /media0/1008/20101120/4ce7d17d.smd size  29857097
Found file entry /media0/1008/20101120/4ce77615.smd size  29858276
Found file entry /media0/1008/20101120/4ce7d2a9.smd size  29860546
Found file entry /media0/1008/20101120/4ce77741.smd size  29859915
Found file entry /media0/1008/20101120/4ce7d3d5.smd size  29854615
Found file entry /media0/1008/20101120/4ce7d501.smd size  29859656
Found file entry /media0/1008/20101120/4ce7d62d.smd size  29864630
Found file entry /media0/1008/20101120/4ce7d759.smd size  29858605
Found file entry /media0/1008/20101120/4ce7d885.smd size  29853231
Found file entry /media0/1008/20101120/4ce7d9b1.smd size  29864863
Found file entry /media0/1008/20101120/4ce7dadd.smd size  29857057
Found file entry /media0/1008/20101120/4ce7dc09.smd size  29855897
Found file entry /media0/1008/20101120/4ce7dd35.smd size  29863416
Found file entry /media0/1008/20101120/4ce7de61.smd size  29854369
Found file entry /media0/1008/20101120/4ce7df8d.smd size  29859191
Found file entry /media0/1008/20101120/4ce7e0b9.smd size  29861623
Found file entry /media0/1008/20101120/4ce7e1e5.smd size  29859136
Found file entry /media0/1008/20101120/4ce7e311.smd size  29873116
Found file entry /media0/1008/20101120/4ce7e43d.smd size  29856167
Found file entry /media0/1008/20101120/4ce7e569.smd size  29858752
Found file entry /media0/1008/20101120/4ce7e695.smd size  29853445
Found file entry /media0/1008/20101120/4ce7e7c1.smd size  29862397
Found file entry /media0/1008/20101120/4ce7e8ed.smd size  29859647
Found file entry /media0/1008/20101120/4ce7ea19.smd size  29852059
Found file entry /media0/1008/20101120/4ce7eb45.smd size  29857087
Found file entry /media0/1008/20101120/4ce7ec71.smd size  29857500
Found file entry /media0/1008/20101120/4ce7ed9d.smd size  29863683
Found file entry /media0/1008/20101120/4ce7eec9.smd size  29852952
Found file entry /media0/1008/20101120/4ce7eff5.smd size  29865765
Found file entry /media0/1008/20101120/4ce7f121.smd size  29856873
Found file entry /media0/1008/20101120/4ce7f24d.smd size  29859226
Found file entry /media0/1008/20101120/4ce7f379.smd size  29849917
Found file entry /media0/1008/20101120/4ce7f4a5.smd size  29848161
Found file entry /media0/1008/20101120/4ce7f5d1.smd size  29869356
Found file entry /media0/1008/20101120/4ce7f6fd.smd size  29859284
Found file entry /media0/1008/20101120/4ce7f829.smd size  29861495
Found file entry /media0/1008/20101120/4ce7f955.smd size  29856978
Found file entry /media0/1008/20101120/4ce7fa81.smd size  29857271
Found file entry /media0/1008/20101120/4ce7fbad.smd size  29854985
Found file entry /media0/1008/20101120/4ce7fcd9.smd size  29854498
Found file entry /media0/1008/20101120/4ce7fe05.smd size  29877184
Found file entry /media0/1008/20101120/4ce7ff31.smd size  29851090
Found file entry /media0/1008/20101120/4ce8005d.smd size  29857444
Found file entry /media0/1008/20101120/4ce80189.smd size  29859819
Found file entry /media0/1008/20101120/4ce802b5.smd size  29865401
Found file entry /media0/1008/20101120/4ce803e1.smd size  29852624
Found file entry /media0/1008/20101120/4ce8050d.smd size  29856408
Found file entry /media0/1008/20101120/4ce80639.smd size  29860696
Found file entry /media0/1008/20101120/4ce80765.smd size  29854593
Found file entry /media0/1008/20101120/4ce80891.smd size  29863049
Found file entry /media0/1008/20101120/4ce809bd.smd size  29854988
Found file entry /media0/1008/20101120/4ce80ae9.smd size  29866520
Found file entry /media0/1008/20101120/4ce80c15.smd size  29857422
Found file entry /media0/1008/20101120/4ce80d41.smd size  29859176
Found file entry /media0/1008/20101120/4ce80e6d.smd size  29860838
Found file entry /media0/1008/20101120/4ce80f99.smd size  29855512
Found file entry /media0/1008/20101120/4ce810c5.smd size  29860393
Found file entry /media0/1008/20101120/4ce811f1.smd size  29856215
Found file entry /media0/1008/20101120/4ce8131d.smd size  29853520
Found file entry /media0/1008/20101120/4ce81449.smd size  29866860
Found file entry /media0/1008/20101120/4ce81575.smd size  29865816
Found file entry /media0/1008/20101120/4ce816a1.smd size  29844869
Found file entry /media0/1008/20101120/4ce817cd.smd size  29869264
Found file entry /media0/1008/20101120/4ce818f9.smd size  29861984
Found file entry /media0/1008/20101120/4ce81a25.smd size  29846692
Sending file /1008/media_master: Sent
Sending file  /1008/20101120/4ce77165.smd: executeJob returned: CURL succeeded
Request  Response:
HTTP/1.0 400 Bad Request
Date: Sunday, 21-Nov-10 11:58:34  GMT
Server: Cisco VSMS-Server
Expires: Sunday, 21-Nov-10 11:58:34  GMT
Pragma: no-cache
Connection: close
Content-Type:  text/plain
Content-Length: 36
No backup directory on this  server
Has anyone else run into this issue?
