Dialing 0 for outside line.
Jun 22nd, 2010
Hi All,
My next issue on the UC540 is the dialing a number for an outside line. In our test setup we have 1x FXO PSTN line and a SIP trunk. The Sip trunk has 10x DIDs and 10 lines.
Now when we make calls we have to dial '0' in our case to get an outside line. The issue is when people call us we cannot call them back from our call history as it is missing the '0'.
What would be the best solution in this case. Remove the need for a 0 (as we would prefer) or manipulate the caller ID?
I have another issue which may or may not be related. With SNR sometimes the UC uses the SIP trunk and sometimes it used the SIP trunk. I would like to set all outgoing calls on the SIP trunk unless all lines are being used. Is there any way to do this?
djh278778 Tue, 06/22/2010 - 09:48
From your call history there is an "edit dial" soft key. You would select the call on the log, press "edit dial",  then "0",  then  "dial". Does this not work for you?
SteveOrfanos Tue, 06/22/2010 - 12:38
In my experience this is a common gripe customers have.
I'm only new to the UC500 space, however I have a lot of experience with Unified Communications in particular with the Mitel product. Mitel can insert in this case an addition 0 to the inward dialing number which allows you to dial straight out of history without having to modify the number.
Is there a way of doing this on the UC500?
P.S. I'm not pitting one system against the other. I think both products are fantastic
David Trad Tue, 06/22/2010 - 13:19
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi Matthew,
If you are comfortable with using the CLI I can help you to resolve this problem.
You need a Translation rule, that will add a "0" to the incoming, so that way when you review it in your history you only need to press redial.
Can you provide the following please:
  • Which country are you in?
  • Upload your running configuration with the removal of all sensitive information
  • Do you require it on both the POTS and the VoIP dial-peers?
This is a common problem, and I am still not sure why this has not been addressed, unless of course it is available in CCA and I am just not aware of it.
Cheers,
David.
matthew.cameron Tue, 06/22/2010 - 21:22
My CLI is great, I am a network engineer. I have tried translation rules already but with no luck. Any help would be
greatly appreciated.
I am in Australia (Melbourne)
Yes we use the SIP trunk for all outgoing calls and the POTS is only for backup if our inraweb breaks
I haven't seen anything in the CCA and it baffles me a little too.
Cheers
Running Config:
Building configuration...
Current configuration : 59883 bytes
! Last configuration change at 14:01:57 AEST Wed Jun 23 2010 by admin
! NVRAM config last updated at 00:19:10 AEST Wed Jun 23 2010
version 15.0
parser config cache interface
no service pad
no service timestamps debug uptime
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no logging rate-limit
enable secret 5 $1$bnv3$f1/I/631VlAWNCIDnm7Tk/
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone AEST 10
clock summer-time AEST recurring last Sun Oct 2:00 last Sun Mar 3:00
crypto pki trustpoint TP-self-signed-1789424616
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1789424616
revocation-check none
rsakeypair TP-self-signed-1789424616
crypto pki certificate chain TP-self-signed-1789424616
certificate self-signed 01
     quit
dot11 syslog
dot11 ssid Vibe Group
vlan 1
authentication open
authentication key-management wpa
guest-mode
dot11 ssid cisco-data
vlan 1
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.0.1.100 10.0.1.255
ip dhcp excluded-address 10.0.1.1 10.0.1.49
ip dhcp excluded-address 10.0.0.100 10.0.0.255
ip dhcp excluded-address 10.0.0.1 10.0.0.49
ip dhcp pool phone
   network 10.0.1.0 255.255.255.0
   default-router 10.0.1.254
   option 150 ip 10.0.1.254
ip dhcp pool data
   import all
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.254
   dns-server 10.0.0.210
ip name-server 10.0.0.210
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 3600 min 3600
   outbound-proxy dns:sip-direct.vic.iibusiness.net.au
  no update-callerid
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class cause-code 1
no-circuit
voice register global
voice hunt-group 1 parallel
final 00405277279
list 201,202,203
timeout 16
pilot 501
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
voice translation-rule 4
rule 1 /0390294381/ /501/
voice translation-rule 6
rule 1 /0380604506/ /202/
voice translation-rule 7
rule 1 /0380604505/ /201/
voice translation-rule 8
rule 1 /0380604500/ /501/
voice translation-rule 410
rule 1 /^0\(.*\)/ /\1/
rule 15 /^...$/ /0380604500/
voice translation-rule 411
rule 1 /^0\(.*\)/ /ABCD0\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1111
rule 1 /201/ /0380604500/
voice translation-rule 1112
rule 1 /^0/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile All-BG_Called_8
translate called 8
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile User#2_Called_6
translate called 6
voice translation-profile User#1_Called_7
translate called 7
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP-BG_Called_4
translate called 4
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice-card 0
license udi pid UC540W-FXO-K9 sn FHK1421710B
archive
log config
  logging enable
  logging size 600
  hidekeys
username admin privilege 15 secret
process-max-time 50
ip tftp source-interface Loopback0
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $ETH-WAN$
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid Vibe Group
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 104 in
ip mtu 1452
ip nat outside
ip inspect SDM_LOW out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 7
ppp pap sent-username vibegroup password
ppp ipcp dns request
interface BVI1
ip address 10.0.0.254 255.255.255.0
ip access-group 102 in
ip nat inside
ip tcp adjust-mss 1412
interface BVI100
ip address 10.0.1.254 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 10.0.0.214 80 interface Dialer0 80
ip nat inside source static tcp 10.0.0.211 25 interface Dialer0 25
ip nat inside source static tcp 10.0.0.211 443 interface Dialer0 443
ip nat inside source static tcp 10.0.0.214 21 interface Dialer0 21
ip nat inside source static tcp 10.0.0.212 3389 interface Dialer0 3389
ip nat inside source static tcp 10.0.0.50 22999 interface Dialer0 22999
ip nat inside source static tcp 10.0.0.214 5721 interface Dialer0 5721
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 10.0.0.254
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 2 permit 10.0.0.0 0.0.0.255
access-list 2 permit 10.0.1.0 0.0.0.255
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 203.55.229.198
access-list 3 deny   any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.0.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.0.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.0.1.0 0.0.0.255 any
access-list 101 deny   ip 10.0.0.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.0.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 10.0.0.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_12##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit tcp any any eq 5721 log
access-list 104 permit tcp any any eq 22999 log
access-list 104 permit tcp any any eq 3389 log
access-list 104 permit tcp any any eq ftp log
access-list 104 permit tcp any any eq 443 log
access-list 104 permit tcp any any eq smtp log
access-list 104 permit tcp any any eq www log
access-list 104 permit udp host 10.0.0.254 eq 5060 any
access-list 104 permit udp host 10.0.0.254 any eq 5060
access-list 104 permit udp any any range 16384 32767
access-list 104 permit udp host 203.55.229.198 eq 5060 any
access-list 104 permit udp host 203.55.229.198 any eq 5060
dialer-list 1 protocol ip permit
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-1-9.bin alias spa525g-7-1-9.bin
tftp-server flash:/phones/5x5/spa5x5-7-1-3c.bin alias spa5x5-7-1-3c.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
bridge 1 route ip
bridge 100 route ip
call threshold interface FastEthernet0/0 int-calls low 4 high 4
voice-port 0/0/0
cptone AU
station-id name Cordless
station-id number 301
caller-id enable
voice-port 0/0/1
cptone AU
station-id number 302
caller-id enable
voice-port 0/0/2
cptone AU
station-id number 303
caller-id enable
voice-port 0/0/3
cptone AU
station-id number 304
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
supervisory disconnect dualtone mid-call
cptone AU
timeouts call-disconnect 3
timeouts wait-release 3
connection plar opx 501
impedance complex1
description Configured by CCA 4 FXO-0/1/0-BG
caller-id enable
voice-port 0/1/1
cptone AU
connection plar 202
shutdown
impedance complex1
caller-id enable
voice-port 0/1/2
cptone AU
connection plar 203
shutdown
impedance complex1
caller-id enable
voice-port 0/1/3
cptone AU
connection plar 204
shutdown
impedance complex1
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.0.1.254 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number .%
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
description ** FXS PORT 0/0/0 **
destination-pattern 301
port 0/0/0
dial-peer voice 2 pots
description ** FXS PORT 0/0/1 **
destination-pattern 302
port 0/0/1
dial-peer voice 3 pots
description ** FXS PORT 0/0/2 **
destination-pattern 303
port 0/0/2
dial-peer voice 4 pots
description ** FXS PORT 0/0/3 **
destination-pattern 304
port 0/0/3
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*Australia*Emergency Services**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 0000
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
description **CCA*Australia*Emergency TTY**
preference 5
destination-pattern 0106
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 106
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*Australia*International Access**
preference 5
destination-pattern 0001[1589]T
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
description **CCA*Australia*Premium Services**
preference 5
destination-pattern 00055T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-local-plus
description **CCA*Australia*Analogue AMPS service**
preference 5
destination-pattern 0014[04689].....
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
description **CCA*Australia*Analogue AMPS & Satellite**
preference 5
destination-pattern 0014[12357]......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0015......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
description **CCA*Australia*Paging Service**
preference 5
destination-pattern 00160..
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0016[1236789].....
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0017[1289].....
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0018......
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
description **CCA*Australia*Data Network Access Service**
preference 5
destination-pattern 00192.
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 00198[01239].....
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 00198[45678]
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*Australia*NSW Numbers**
preference 5
destination-pattern 002........
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
description **CCA*Australia*VIC, TAS Numbers**
preference 5
destination-pattern 003........
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_FXO
description **CCA*Australia*Digital Mobile Service**
preference 5
destination-pattern 004........
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
description **CCA*Australia*Universal Personal Comms Service**
preference 5
destination-pattern 005........
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup ALL_FXO
description **CCA*Australia*QLD Numbers**
preference 5
destination-pattern 007........
forward-digits all
no sip-register
dial-peer voice 79 pots
trunkgroup ALL_FXO
description **CCA*Australia*SA, WA, NT Numbers**
preference 5
destination-pattern 008........
forward-digits all
no sip-register
dial-peer voice 80 pots
trunkgroup ALL_FXO
description **CCA*Australia*Community Service**
preference 5
destination-pattern 01100
forward-digits all
no sip-register
dial-peer voice 81 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0110[1-9]..
forward-digits all
no sip-register
dial-peer voice 82 pots
trunkgroup ALL_FXO
description **CCA*Australia*Public Interest Service**
preference 5
destination-pattern 0113...
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup ALL_FXO
description **CCA*Australia*Mass Calling Service**
preference 5
destination-pattern 0114.....
forward-digits all
no sip-register
dial-peer voice 84 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0119.
forward-digits all
no sip-register
dial-peer voice 85 pots
trunkgroup ALL_FXO
description **CCA*Australia*Directory and Service Numbers**
preference 5
destination-pattern 0122[1235]
forward-digits all
no sip-register
dial-peer voice 86 pots
trunkgroup ALL_FXO
description **CCA*Australia*Directory and Operator Numbers**
preference 5
destination-pattern 0123[46]
forward-digits all
no sip-register
dial-peer voice 87 pots
trunkgroup ALL_FXO
description **CCA*Australia*Operator Service**
preference 5
destination-pattern 012[45]T
forward-digits all
no sip-register
dial-peer voice 88 pots
trunkgroup ALL_FXO
description **CCA*Australia*Local Rate Numbers**
preference 5
destination-pattern 0130.......
forward-digits all
no sip-register
dial-peer voice 89 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 013[1-9]...
forward-digits all
no sip-register
dial-peer voice 90 pots
trunkgroup ALL_FXO
description **CCA*Australia*Carrier Preselection Codes**
preference 5
destination-pattern 014[1-9]T
forward-digits all
no sip-register
dial-peer voice 91 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*Australia*Freephone Numbers**
preference 5
destination-pattern 0180[01]......
forward-digits all
no sip-register
dial-peer voice 92 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0180[2-9]...
forward-digits all
no sip-register
dial-peer voice 93 pots
trunkgroup ALL_FXO
description **CCA*Australia*Universal PCS Profile Management**
preference 5
destination-pattern 0185..
forward-digits all
no sip-register
dial-peer voice 94 pots
trunkgroup ALL_FXO
description **CCA*Australia*Calling Card Service**
preference 5
destination-pattern 0189..
forward-digits all
no sip-register
dial-peer voice 95 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 0190[0126]......
forward-digits all
no sip-register
dial-peer voice 96 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 019[1345]...
forward-digits all
no sip-register
dial-peer voice 97 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 019[679].....
forward-digits all
no sip-register
dial-peer voice 98 pots
trunkgroup ALL_FXO
description **CCA*Australia*8-digit dialing**
preference 5
destination-pattern 0[2-9].......
forward-digits all
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (Generic SIP Trunk Provider) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1021 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1022 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1026 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1027 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1028 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1029 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1030 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1031 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1032 voip
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1033 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1034 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1035 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1036 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1037 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1038 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1039 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1040 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1041 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1042 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1043 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1044 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1045 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1046 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1047 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1048 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1049 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1050 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1051 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1052 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1053 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1054 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1055 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1056 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1057 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1058 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1059 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1060 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3000 voip
description SIP-BG
translation-profile incoming SIP-BG_Called_4
incoming called-number 0390294381
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 48 voip
translation-profile incoming sip_trunk
translation-profile outgoing wash_cli
destination-pattern .....T
session target dns:vibegroup01.iibusiness.net.au
incoming called-number 0380604500-0380604519
voice-class codec 1
voice-class sip asserted-id pai
dtmf-relay rtp-nte
dtmf-interworking rtp-nte
dial-peer voice 3002 voip
description LeeDemetrious
translation-profile incoming LeeDemetrious_Called_6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3003 voip
description MatthewCameron
translation-profile incoming MatthewCameron_Called_7
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3004 voip
description All-BG
translation-profile incoming All-BG_Called_8
voice-class codec 1
dtmf-relay rtp-nte
no vad
no dial-peer outbound status-check pots
sip-ua
authentication username password
calling-info pstn-to-sip asserted-id number set
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.0.1.254 port 2000
auto assign 10 to 43
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Vibe Group
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-1-9
load 501G spa5x5-7-1-3c
load 502G spa5x5-7-1-3c
load 504G spa5x5-7-1-3c
load 508G spa5x5-7-1-3c
load 509G spa5x5-7-1-3c
time-zone 48
time-format 24
date-format dd-mm-yy
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$uwDC$j8UG5FNQIJ86ciRy7tpnj1
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 0.T
transfer-pattern 6... blind
secondary-dialtone 0
directory entry 1 00405277279 name Matthew Mobile
directory entry 2 201 name Matthew
directory entry 3 202 name Lee
directory entry 4 203 name Jim
fac standard
create cnf-files version-stamp 7960 Jun 08 2010 21:20:56
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys idle  Redial Newcall Mobility Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Mobility Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 201 secondary 0380604505 no-reg both
label 201
description Matthew Cameron
name Matthew Cameron
mobility
snr 00405277279 delay 5 timeout 30 cfwd-noan 399
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn  11  dual-line
number 202 secondary 0380604506 no-reg both
label 202
description Lee Demetrious
name Lee Demetrious
ephone-dn  12  dual-line
number 203 no-reg primary
label 203
description Jim Simos
name Jim Simos
ephone-dn  13  dual-line
number 204 no-reg primary
label 204
description 204
name 204
ephone-dn  14  dual-line
number 205 no-reg primary
label 205
description 205
name 205
ephone-dn  15  dual-line
number 206 no-reg primary
label 206
description 206
name 206
ephone-dn  16  dual-line
number 207 no-reg primary
label 207
description 207
name 207
ephone-dn  17  dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn  18  dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn  19  dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone-dn  20  dual-line
number 211 no-reg primary
label 211
description 211
name 211
ephone-dn  21  dual-line
number 212 no-reg primary
label 212
description 212
name 212
ephone-dn  22  dual-line
number 213 no-reg primary
label 213
description 213
name 213
ephone-dn  23  dual-line
number 214 no-reg primary
label 214
description 214
name 214
ephone-dn  24  dual-line
number 215 no-reg primary
label 215
description 215
name 215
ephone-dn  25  dual-line
number 216 no-reg primary
label 216
description 216
name 216
ephone-dn  26  dual-line
number 217 no-reg primary
label 217
description 217
name 217
ephone-dn  27  dual-line
number 218 no-reg primary
label 218
description 218
name 218
ephone-dn  28  dual-line
number 219 no-reg primary
label 219
description 219
name 219
ephone-dn  29  dual-line
number 220 no-reg primary
label 220
description 220
name 220
ephone-dn  30  dual-line
number 221 no-reg primary
label 221
description 221
name 221
ephone-dn  31  dual-line
number 222 no-reg primary
label 222
description 222
name 222
ephone-dn  32  dual-line
number 223 no-reg primary
label 223
description 223
name 223
ephone-dn  33  dual-line
number 224 no-reg primary
label 224
description 224
name 224
ephone-dn  34  dual-line
number 225 no-reg primary
label 225
description 225
name 225
ephone-dn  35  dual-line
number 226 no-reg primary
label 226
description 226
name 226
ephone-dn  36  dual-line
number 227 no-reg primary
label 227
description 227
name 227
ephone-dn  37  dual-line
number 228 no-reg primary
label 228
description 228
name 228
ephone-dn  38  dual-line
number 229 no-reg primary
label 229
description 229
name 229
ephone-dn  39  dual-line
number 230 no-reg primary
label 230
description 230
name 230
ephone-dn  40  dual-line
number 231 no-reg primary
label 231
description 231
name 231
ephone-dn  41  dual-line
number 232 no-reg primary
label 232
description 232
name 232
ephone-dn  42  dual-line
number 233 no-reg primary
label 233
description 233
name 233
ephone-dn  43  dual-line
number 234 no-reg primary
label 234
description 234
name 234
ephone-dn  44  dual-line
number 235 no-reg primary
label 235
description 235
name 235
ephone-dn  45  dual-line
number 236 no-reg primary
label 236
description 236
name 236
ephone-dn  297
number 0380604500
description SIP Main Number registration
preference 10
ephone-dn  298
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
ephone  5
device-security-mode none
video
mac-address 0026.998D.2D78
ephone-template 16
max-calls-per-button 2
username "MatthewCameron" password nqr87092
type 525G
button  1:10 2m11 3m12
ephone  6
video
mac-address 8843.E155.10E8
ephone-template 16
username "LeeDemetrious" password 123456
type 504G
button  1:11 2m10 3m12
ephone  7
video
mac-address C47D.4F06.5729
ephone-template 16
username "JimSimos" password 123456
type 504G
button  1:12 2m10 3m11
alias exec cca_voice_mode PBX
banner login ^CCisco Configuration Assistant. Version: 2.2 (4). Tue Jun 08 20:58:33 EST 2010^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 5 100
ntp master
end
David Trad Tue, 06/22/2010 - 23:48
    2013 Small Business
Hi Matthew,
Just as a test could you apply this to one of your translation profiles?
rule 2 /^...$/ /0380604500/
rule 3 /^4/ /004/
rule 4 /^7/ /007/
rule 5 /^3/ /0073/
rule 6 /^02/ /002/
rule 7 /^08/ /008/
rule 8 /^03/ /003/
rule 9 /^2/ /002/
rule 10 /^8/ /008/
Look I honestly am not sure if it will work, this only normally gets applied to ISDN/DID services where you get more control over this type of stuff, but rules 3-10 normally take care of the issue you are experiencing, they are the very one I use on pretty much all deployments.
Your current setup baffles me a little, I am not sure why you are running translation rules when you are already plaring the FXO ports to either a PHG or an extension, sadly I don't have enough time on my hands at the moment to go over your whole config and try and work out exactly what is going on, but please give the above a try and let me know how it goes (I am about 30% confident it will yield a result, but doubtful would be more accurate).
I'll keep working with you on this one untill we get a good outcome.
Cheers,
David.
