06-22-2010 07:12 AM - edited 03-14-2019 05:55 AM
The standone of EIM/WIM works fine. I can run the setup wizard to integrate with ICM. But when I try to start the EAAS and Listener instance but it fail to start. Attached file is the popup error. Any one can help me on this?
Why it says no process avaiable? I check along with there are no file or log file relate to the name of EAAS or Listener.
regards,
Solved! Go to Solution.
06-22-2010 06:28 PM
Log in as the system administrator (not the partition admin) and check that the parent processes for the EAAS and the Listener have been started. You cannot start an instance process if the parent process is not running. All EIM processes are like this. Parent at the system level, child at the partition level.
Still, I have done MANY integrations and it should work, so I am suspicious that it has not integrated correctly.
Geoff
06-22-2010 06:28 PM
Geoff
06-22-2010 07:46 PM
Hi Geoff,
You are correct!!!!!!!!
Thank you very much.
Thanh
