Reg. ASA 5510 Base license mgmt interface query
Jun 22nd, 2010
Can we configure ASA 5510 with base license to make the management interface run as the data interface . If yes , let me know
if there is any document for the same
Federico Coto F... Tue, 06/22/2010 - 11:26
As far as I'm aware, you can use the management interface as a data interface by just changing the ''management-only'' under the interface.
The restriction based on license is if you have a base license all five interfaces are 10/100, but if you have the security plus license, 2 of those interfaces can run at 10/100/1000
ankurs2008 Tue, 06/22/2010 - 13:11
Please let me know if there is document available regarding the same .
ankurs2008 Tue, 06/22/2010 - 15:48
I cud not finding anything related to the above question in the URL given
Federico Coto F... Tue, 06/22/2010 - 16:00
That link says you can turn the management interface into a data interface with the command ''no management-only'' and there's no license required to do that.
I happen to have an ASA-5510 with Base License sitting here with me:
GTI-Secure# sh ver
Cisco Adaptive Security Appliance Software Version 8.0(4)
Detected an old ASDM version.
You will need to upgrade it before using ASDM.
Compiled on Thu 07-Aug-08 20:53 by builders
System image file is "disk0:/asa804-k8.bin"
Config file at boot was "startup-config"
GTI-Secure up 117 days 9 hours
Hardware:   ASA5510-K8, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Ext: Ethernet0/0         : address is 000a.b89c.c802, irq 9
1: Ext: Ethernet0/1         : address is 000a.b89c.c803, irq 9
2: Ext: Ethernet0/2         : address is 000a.b89c.c804, irq 9
3: Ext: Ethernet0/3         : address is 000a.b89c.c805, irq 9
4: Ext: Management0/0       : address is 000a.b89c.c806, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 50
Inside Hosts                 : Unlimited
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 0
GTP/GPRS                     : Disabled
VPN Peers                    : 250
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
This platform has a Base license.
interface Management0/0
no nameif
no security-level
no ip address
GTI-Secure(config)# int mana
GTI-Secure(config)# int management 0/0
GTI-Secure(config-if)# no management-only
GTI-Secure(config-if)# exit
no nameif
no security-level
no ip address
So, the management interface can be used as a data interface.
Jennifer Halim Mon, 06/28/2010 - 03:16
Yes, the management interface can be used to pass normal data traffic when you disable "management-only" from the management interface with ASA 5510 base license when you are running version 7.2.2 and above if i am not mistaken. The earlier version of code with ASA 5510 base license only allows the management interface as management only interface, not data traffic.
Jennifer Halim Mon, 06/28/2010 - 03:56
The document is correct for the earlier version of ASA code. The later version of code supports management interface as a data or pass through interface.
Initially when ASA 5510 was just introduced, base license was only restricted to 3 interfaces with 1 management interface (that only allows mgmt traffic). However, since 7.2.2, ASA 5510 with base license allow 5 interfaces, and the mgmt interface can be used to pass traffic.
