Basic Concept of Xconnect in the case of AToM
inderdeeps
Level 4
Level 4
Hello
What is the basic concept of Xconnect in the case of AToM?
How AToM can be implemented in the live networks? What are the issues that can faced in the AToM technology?
I am unavair of this concept as i need to start this topic, Pls help me out how can i start to implement this?
Thanxs in advance for guiding me....
Regards!!!
Inderdeep
2 Accepted Solutions
Hi Inder
You could also get good information from given link
http://www.mplsvpn.info/search/label/L2VPN
regards
Shivlu Jain
Mohamed Sobair
Level 7
Level 7
AToM is the way of carrying layer-2 protocols over MPLS. these layer-2 protocols are , Ethernet , HDLC , PPP , Frame-relay, and ATM.
The L2VPN is carried in point to point fashion and its TTL value always set to 2 , the top label is the tunnel label and the inner label is always going to be the VC label
VPLS is carried in point to multipoint fashion and its TTL value alwys set  to 255.
Ethernet Over MPLS allows CDP,STP, and VTP to be tunneled over MPLS.
Ethernet Over MPLS has two Modes:
1- Port Mode
2- Vlan Mode
Besides what others has suggested, Bellow is one excellent resource:
---  Layer 2 VPN Architecture (Cisco press)
Mohamed
6 Replies 6
Giuseppe Larosa
Thanxs for sharing your knowledge....
Inderdeep
http://www.networksbaseline.in/
Hi Inder
regards
Shivlu Jain
Hi Indeer
Please find the attach sample config. Were you can get an good idea to cofigure AToM.
& also please refer the below link were you can learn more about AToM.
http://fengnet.com/book/MPLS%20Configuration%20on%20Cisco%20IOS%20Software/ch11.html
Chetan Kumar
Thanxs shivlu and chetan...
Cheers!!!
Inderdeep
http://www.routexp.com
http://www.networksbaseline.com
Mohamed Sobair
Level 7
Level 7
1- Port Mode
2- Vlan Mode
Mohamed
