Maximum Number of HSRP Standby Routers
Jun 22nd, 2010
What would a maximum number of HSRP Standby Routers be?
I have an implementation where it makes sense to have six routers share a VIP for an HSRP configuration.  Are there any problems with having so many standbys in an HSRP group?
James
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 06/22/2010 - 12:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
James
James
No actual upper limit as such although 4 is the most i have used. Note that you will have one active and one standby and then the others will be in listen state only. If the standby fails then one of these will be elected standby.
So there is no reason i know of as to why you couldn't use 6 if you wanted to.
Jon
Ganesh Hariharan Tue, 06/22/2010 - 23:49
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
James
James,
As such no limitation on number for standby routers but is there specific requirement to have 5 standby router with 1 active in group.
Check out the below link for limitaion of groups
http://www.cisco.com/en/US/products/hw/switches/ps700/products_qanda_item09186a008011c6bb.shtml
Hope to Help !!
Ganesh.H
