Cisco 851W with Comcast cable
sudip.acharya1
  I am running into an issue configuring the 851w at my home. I have a Comcast cable modem which the 851w plugs into. Any clients connected to the 851w (lan or wireless) get the right ip's but that’s all. No client can get to the internet or even ping any outside address such as Comcast's DNS servers. I have posted the config for your help.
Also, how can I see the IP FA4 got from the cable modem?
Additionally, when I left the wifi unencrypted/open, none of my clients were able to join. As soon as I set WEP, each client joined immediately. How can I leave the wifi completely open?
Thanks in advance.
no service pad
hostname Longport
boot-start-marker
boot-end-marker
logging console informational
enable --------------------
enable password -------
no aaa new-model
dot11 syslog
dot11 ssid LongPort
  vlan 1
    authentication open
    guest-mode
no ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp pool lan
    import all
    network 192.168.1.0 255.255.255.0
    default-router 192.168.1.1
    domain-name domain
    dns-server 68.87.64.150 68.87.75.198
    lease 14
no ip cef
ip name-server 68.87.64.150  <- I got these from Comcast
ip name-server 68.87.75.198
ip dhcp-server 192.168.1.1
archive
  log config
   hidekeys
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
  description $ES_WAN$
  ip address dhcp client-id FastEthernet4
  no ip route-cache
  duplex auto
  speed auto
interface Dot11Radio0
  no ip address
  no ip route-cache
  encryption vlan 1 key 1 size 40bit 0 00B53450E4 transmit-key
  encryption vlan 1 mode wep mandatory
  broadcast-key vlan 1 change 30
  ssid LongPort
  speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
  station-role root
  bridge-group 1
  bridge-group 1 subscriber-loop-control
  bridge-group 1 spanning-disabled
  bridge-group 1 block-unknown-source
  no bridge-group 1 source-learning
  no bridge-group 1 unicast-flooding
interface Dot11Radio0.1
  encapsulation dot1Q 1 native
  no ip route-cache
  bridge-group 1
interface Vlan1
  no ip address
  no ip route-cache
  bridge-group 1
interface BVI1
  description $ES_LAN$
  ip nat inside
  ip virtual-reassembly
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
no ip http secure-server
ip nat source list Nat_allowed interface FastEthernet4 overload
ip access-list standard Nat_allowed
  permit 192.168.1.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
  password -------------
  login
  no modem enable
line aux 0
line vty 0 4
password --------------
  login
scheduler max-task-time 5000
10 Replies 10
Jerry Ye
I see two problems so far. You didn't enable ip routing and there isn't ip nat outside on Fa4.
ip routing
interface fa4
ip nat outside
jerry
Thanks, i'll try that.
Any idea how i can find out the dhcp address that int4 got?
show ip int brief show give you the information you need.
jerry
I tried the commands but still no internet access.
Can you post the latest show run?
jerry
Here you go.
Thanks.
no service pad
service password-encryption
hostname Longport
boot-start-marker
boot-end-marker
enable secret ---
enable password ---
no aaa new-model
dot11 syslog
dot11 ssid LongPort
vlan 1
   authentication open
   guest-mode
ip dhcp pool lan
   import all
   domain-name domain
   lease 14
ip cef
archive
log config
  hidekeys
bridge irb
ip nat outside
duplex auto
speed auto
no ip address
encryption vlan 1 key 1 size 40bit 7 C02C415A939E transmit-key
ssid LongPort
station-role root
bridge-group 1
bridge-group 1
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface BVI1
ip nat inside
ip route 0.0.0.0 0.0.0.0 FA4
no ip classless
ip http server
control-plane
bridge 1 route ip
line con 0
password ------ login
no modem enable
line aux 0
line vty 0 4
login
end
Okay, spot more mistake, do the following trace route from your desktop to a website via their IP address and post the result.
no ip nat source list Nat_allowed interface FastEthernet4 overload
ip nat inside source list Nat_allowed interface FastEthernet4 overload
ip classless
Windows command in cmd
nslookup
tracert
jerry
Here is the config that works perfectly.
Not sure what the issue was but i erased the config and started from scratch.
no service pad
hostname LongPort
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret ---------
no aaa new-model
dot11 syslog
dot11 ssid Longport
   vlan 1
   authentication open
   guest-mode
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   dns-server 68.87.64.150 68.87.75.198  <----DNS server from comcast
   lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
username admin privilege 15 secret ----------------
archive
log config
  hidekeys
bridge irb
ip nat outside
duplex auto
speed auto
no ip address
no ip route-cache cef
no ip route-cache
ssid Longport
station-role root
bridge-group 1
no ip route-cache
no cdp enable
bridge-group 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
bridge 1 route ip
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
length 0
transport input telnet ssh
The two configs are radically different, I dont think a reboot added all the lines, maybe......the IPs first of all went from Class A to C...do a line by line fc on it...interesting!
Right, i did more than just a reboot. I redid the entire config using a different private ip range to avoid getting myself confused. I think i had misconfigured nat in the previous config.
