10Gb fiber NIC and 2960g
Jun 22nd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
Can 10Gb fiber from a 10Gb NIC in a server run on a 1000BaseSX GBIC (GLC-SX-MM) in a 2960G Cisco switch at 1Gb rate?
Or do I need a different GBIC for the 2960G, or a completely different switch altogether?
Is 10Gb backward compatible via Fiber or do I need to get a copper 10Gb NIC for that?
Jerry Ye Tue, 06/22/2010 - 13:26
The 1G SFP (GLC-SX-MM) will not be able to talk to the 10GB NIC of a server. 1GB and 10GB are not auto-negotiatable.
jerry
Leo Laohoo Tue, 06/22/2010 - 14:55
The 2960S can support 10Gb.  3560E, 3750E/3750X also supports 10Gb.
