How to deny outside incoming ICMP to ASA 5520
Answered Question
Jun 22nd, 2010
I thought any incoming traffic from the outside interface of an ASA 5520 is denied by default. From home, I can ping the public IP.  Any explanation?
Our 5520 is connected via DSL router to the cloud. The DSL is allowing ICMP. I created an access rule to deny any ICMP from the DSL router. No avail, I can still ping reply from the ASA.
Any help/suggestion is appreciated.
Del
Correct Answer by Panos Kampanakis about 6 years 11 months ago
I did not suggest an ACL.
I suggested the command  "icmp deny any " on the ASA.
That will do it.
Rate helpful posts.
PK
The ASA will respond to pings by default.
If you are pinging the ASA then use "icmp deny any " on the ASA and it will drops the pings to it.
I hope it helps.
PK
Correct Answer by Federico Coto F... about 6 years 11 months ago
By default all traffic from the outside to the inside is denied by default.
But this applies to pass-thru traffic through the ASA (not to traffic to the ASA itself).
What are you PINGing from the outside?
Federico.
Overall Rating: 5 (3 ratings)
Correct Answer
Federico Coto F... Tue, 06/22/2010 - 14:02
  • Green, 3000 points or more
Federico.
Delfino Tiongco Wed, 06/23/2010 - 10:50
I am pinging from my home to the ASA.  There is a DSL router before the ASA and is allowing ping.
Correct Answer
Panos Kampanakis Tue, 06/22/2010 - 14:51
  • Cisco Employee,
I hope it helps.
PK
Delfino Tiongco Wed, 06/23/2010 - 10:52
PK
I did write the ACL and I can still ping from the outside. I even tried an ACL to deny ICMP from the DSL router/modem to the ASA. ping still gets through.
Correct Answer
Panos Kampanakis Wed, 06/23/2010 - 11:15
  • Cisco Employee,
That will do it.
Rate helpful posts.
PK
Related Content
