Outbound caller-id translation
Jun 22nd, 2010
I am looking at doing some outgoing caller-id translations based on the area code that is dialed from a phone. The extension that the call is placed from doesn't matter. There is a PRI with phone numbers from various are codes.
Example 1: A call is placed from extension 200 to 555-123-4567. There is a number on the PRI 555-987-6543. For that call only the caller-id displayed would be 555-987-6543
Example 2: A call is placed from extension 200 to 444-123-4567. There is a number on the PRI 444-987-6543. For that call only the caller-ed displayed would be 444-987-6543
The calls are only place to certain area code, so not all area code would need to match. I am thinking that this can be done with dial-peers and translation-profiles and translation-rules, but I was wondering if there is a better/simpler way to accomplish this. If anyone has done something similar would appreciate the advice.
thanks in advance.
David Trad Thu, 06/24/2010 - 22:16
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi Dan,
You would only need to control this via Translation Rules, you would apply the rule via a Translation Profile, and in order to make sure it works you need to apply that profile to your Dial-Peers.
You can test this if you have the time by duplicating your dial-peers and using a different prefix for dialing out, this way if it works you can delete the duplicates and then get your main ones to run with the profile setup.
I hope this gives you the basic answer you were looking for, I am not aware of any other format that is easier or that can do it.
Cheers,
David.
Related Content
