ip phone redirect button
hanimolani
Dear All
I Have cucm 8.0 with cisco ip phone 7945
my problem is when someone call me during my conversation with my ip phone
i want redirect the call to my secretary
i added "Redirect" softkey to my ip phone during "ring-in"
but the button is inactive
any idea please
Jaime Valencia
Have you already configured IPMA to use that softkey???
Cisco Unified Communications Manager  Assistant With Proxy Line Support
When the assistant logs in from the Assistant  Console, the softkeys Redirect and Transfer to Voice Mail become active  for the proxy lines. Refer to the Cisco Unified  Communications Manager Assistant User Guide for more information.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fsipma.html
Unless you're using IPMA the softkey is useless.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Rob Huffman
Hi Hani,
I'm not really sure about the Redirect Softkey, as it is not shown on our CUCM
But I'm guessing that it may be the equivalent of DND...if so;
In CUCM 8.x the Call Reject function
will follow the Call Forward No Answer setting on a phone, so if the CFNA is configured to go
to Voicemail then the call will flow that way in DND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsdnd.html#wp1073696
Normal Call with DND and Call Forward No Answer Enabled on a Nonshared Line
The following steps show the call flow for a call that you make to a phone with both DND and Call Forward No Answer active:
1. Phone B configures Call Forward No Answer to forward calls to Phone C.
2. Phone B activates DND.
3. Phone A calls Phone B.
4. Phone B beeps and does not answer the call.
5. The call gets forwarded to phone C, which rings normally.
In your case use DN xxxx (the Secretary DN)to replace phone C in both steps 1 and 5
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Jaime Valencia
java
java
