Sending & Receing Packets in different link
Jun 23rd, 2010
Hello all,
I am trying to implement a solution where the outgoing traffic will go through a low bandwidth secondary link, where as the incomming packets or the reply packets will come through a high bandwidth primary link.
Is this can be done? Or do i need a 3rd party devices to do this? The reason I am trying to acheive this solution is, both the WAN links are expnisve Sattelite links.
Any thoughts?
Nimal
Paolo Bevilacqua Wed, 06/23/2010 - 02:00
  • Hall of Fame,
    Founding Member
Yes, it can be done. I recommend you engage a reputable consultant or certified cisco partner for the configuration details.
nimalrajphilips Wed, 06/23/2010 - 02:25
Is that is so difficult?
Our company doesnt have any support packages from Cisco / Partner. So i have to figure it out by myself?
Are there any links or basic guidlines to do that?
Cheers
