Intervlan Routing Issue
sharma.advait
I am not able to communicated between vlan 1, 2,3, although inter vlan routing is enabled on cisco 3750 l3 switch.
Bellow is the configuration.
Please suggest on it
APHS_CORE#sh running-config
Building configuration...
Current configuration : 7022 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname APHS_CORE
enable secret 5 $1$ZIFI$evixjAIDgo9nV/451.v9U0
enable password 7 14050107
no aaa new-model
switch 1 provision ws-c3750g-48ts
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
description WS-038
switchport access vlan 2
spanning-tree portfast
interface GigabitEthernet1/0/2
description WS-010
interface GigabitEthernet1/0/3
description WS-007
interface GigabitEthernet1/0/4
description WS-009
interface GigabitEthernet1/0/5
description UD01
switchport access vlan 3
storm-control multicast level 0.05
interface GigabitEthernet1/0/6
description PI01
interface GigabitEthernet1/0/7
description PI02
interface GigabitEthernet1/0/8
description LP01
interface GigabitEthernet1/0/9
description HL01
interface GigabitEthernet1/0/10
description EN02
interface GigabitEthernet1/0/11
description HL02
interface GigabitEthernet1/0/12
description WS-011
interface GigabitEthernet1/0/13
description OT1DF2
interface GigabitEthernet1/0/14
description PB2LP1
interface GigabitEthernet1/0/15
description PB1CS12
interface GigabitEthernet1/0/16
description PB6LP1
interface GigabitEthernet1/0/17
description PB1HL1
interface GigabitEthernet1/0/18
description WS-039
interface GigabitEthernet1/0/19
description LP02
interface GigabitEthernet1/0/20
description LP03
interface GigabitEthernet1/0/21
description EN01
interface GigabitEthernet1/0/22
description PB2HL1
interface GigabitEthernet1/0/23
description HL03
interface GigabitEthernet1/0/24
description PB1CS34
interface GigabitEthernet1/0/25
description RB01
interface GigabitEthernet1/0/26
description DR-SERVER-LEVEL1
interface GigabitEthernet1/0/27
description DR-SERVER-LEVEL2
interface GigabitEthernet1/0/28
description SAL-SERVER1-LEVEL1
interface GigabitEthernet1/0/29
description SAL-SERVER2-LEVEL1
interface GigabitEthernet1/0/30
description SAL-SERVER1-LEVEL2
interface GigabitEthernet1/0/31
description SAL-SERVER2-LEVEL2
interface GigabitEthernet1/0/32
description CR-WS01-LEVEL2
interface GigabitEthernet1/0/33
description CR-WS02-LEVEL2
interface GigabitEthernet1/0/34
description CR-WS03-VLAN1
interface GigabitEthernet1/0/35
description CR-WS04-VLAN1
interface GigabitEthernet1/0/36
description CR-WS05-VLAN1
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
switchport mode trunk
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 10.36.24.1 255.255.255.0
standby ip 10.36.24.4
interface Vlan2
ip address 10.36.25.241 255.255.255.0
standby ip 10.36.25.243
standby priority 110
interface Vlan3
ip address 10.36.26.241 255.255.255.0
standby ip 10.36.26.243
ip classless
ip route 0.0.0.0 0.0.0.0 10.36.24.3
ip http server
ip access-list extended SAL1
permit udp 10.36.26.0 0.0.0.255 host 10.22.19.16
permit udp any any
ip access-list extended SAL1_out
permit ip host 10.22.19.16 10.36.26.0 0.0.0.255
permit ip host 10.2.219.91 10.36.26.0 0.0.0.255
permit ip host 10.2.161.16 10.36.26.0 0.0.0.255
permit ip host 10.44.108.110 10.36.26.0 0.0.0.255
ip access-list extended SAL2
permit ip 10.36.25.0 0.0.0.255 host 10.22.19.16
permit udp any any
permit ip 10.36.25.0 0.0.0.255 host 10.44.108.110
permit ip 10.36.25.0 0.0.0.255 host 10.2.219.91
deny   ip any any
ip access-list extended SAL2_out
permit ip host 10.2.161.16 10.36.25.0 0.0.0.255
permit udp any any
permit ip host 10.22.19.16 10.36.25.0 0.0.0.255
permit ip host 10.44.108.110 10.36.25.0 0.0.0.255
permit ip host 10.2.219.91 10.36.25.0 0.0.0.255
access-list 101 deny   ip any any
access-list 102 deny   ip any any
access-list 111 deny   igmp any any
snmp-server community public RO
snmp-server location APHS Control Room
snmp-server contact Suresh Malviya
control-plane
line con 0
line vty 0 4
password 7 104F191116
login
line vty 5 15
password 7 141602031F
login
end
16 Replies 16
Hitesh Vinzoda
Level 4
Level 4
If possible, pls post sh ip route and sh vlan of the switch
Hitesh Vinzoda
Pls rate useful posts
sh ip route
Gateway of last resort is 10.36.24.3 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 3 subnets
C       10.36.26.0 is directly connected, Vlan3
C       10.36.24.0 is directly connected, Vlan1
C       10.36.25.0 is directly connected, Vlan2
S*   0.0.0.0/0 [1/0] via 10.36.24.3
10.36.24.3 is router and a static route is given for it
sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/34, Gi1/0/35, Gi1/0/42
                                                Gi1/0/43, Gi1/0/44, Gi1/0/45
2    VLAN0002                         active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/12, Gi1/0/18
                                                Gi1/0/27, Gi1/0/30, Gi1/0/31
                                                Gi1/0/33, Gi1/0/36, Gi1/0/37
                                                Gi1/0/38, Gi1/0/39, Gi1/0/40
3    VLAN0003                         active    Gi1/0/5, Gi1/0/6, Gi1/0/7
                                                Gi1/0/8, Gi1/0/9, Gi1/0/10
                                                Gi1/0/11, Gi1/0/13, Gi1/0/14
                                                Gi1/0/15, Gi1/0/16, Gi1/0/17
                                                Gi1/0/19, Gi1/0/20, Gi1/0/21
                                                Gi1/0/22, Gi1/0/23, Gi1/0/24
                                                Gi1/0/25, Gi1/0/26, Gi1/0/28
                                                Gi1/0/29, Gi1/0/32, Gi1/0/41
                                                Gi1/0/46
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
Configure a Routing protocol like EIGRP or RIP v2 in switch for all the vlan Networks.
You're not using a Router for Intervlan Communication.
Normally if ur not using Router in a stick for Intervlan communication, you need to configure a Routing Protocol like EIGRP or RIP.
Best Regards,
Dasuntha
I have already used following commands on the switch
ip routing
router ospf
I thing above commands will enable inter vlan routing.
If you configured ospf properly, we can see routes learned from OSPF.
But in your routing table, I cant see any routes learned from OSPF.
So, double check the OSPF config.
Or show me ur config & i can double check for you.
Dasuntha
Advait,
wonder how ospf/eigrp or rip enables inter vlan routing here, unless untill you want to send subnets attached with the Vlans to another device
Just breezed through your configurations:-
1.You need to check whether the "trunking" is happening with the outher switches first. (sh interfaces trunk)
2.The Associated hosts in the Vlan should point to their respective SVI's as gateway. (ping test)
Could you explain the need for Standby ?
3. If using standby in you design, your hosts should point to the standby address configured in the SVI's.
Better if you could get it working in a normal way before hardening it.
Post "sh standy brief" from both the switches, also do you have a link between 2 switches.
Hitesh Vinzoda
What IP address have you specified as the gateway on hosts ?
Is it the HSRP virtual IP address ? For example for hosts connected to VLAN 1 should have the gateway 10.36.24.4
Is that correct ?
Thanks & Regards
Zeeshan Sanaullah
Hi Tharak,
You can see in the question that, he is using only 3 switches. No Router.
So, for inter vlan communication, you need a Layer 3 Switch to do the routing between each vlan.
Otherwise you cant communicate with each vlan subnet.
I used this setup using EIGRP & L3 switch & its working fine.
And routing much faster than when we used a Router.
Pls test this & you'll see it.
Dasuntha
Dasuntha,
He's using a L3 switch or he wouldn't be able to enable routing on it. That aside, regardless of the routing protocol being used, the OP should be able to ping all 3 vlans from a host in ANY vlan on that switch as long as the default gateway for the host is correct. Also, it doesn't matter if the HSRP address is used as the gateway or the physical address.
Tharak,
If a host is connected to the switch, does the vlan show to be up?
Can you ping the physical address from the host of the vlan that it's a member of? (ping the vlan2 address if you're connected to a port that is in that vlan).
If you get a response, can you ping vlan 1?
Do you have edge switches connected to the 3750 and trying to ping from the edge switch?
HTH,
John
HTH, John *** Please rate all useful posts ***
John,
That's what I said.
When we use L3 switches for InterVLAN routing, we need to configure Routing Protocol like RIP, EIGRP or OSPF.
Otherwise Inter VLAN communication will not work.
YOu can see from this SH Ip Route output that no route was learnt from OSPF.
That means its not configured properly.
Dasuntha
Hi Dasuntha Dinesh,
Tharak Abraham is right, You do need any routing protocol for InterVLAN to work. The routing protocol output shows all VLAN subnets as connected routes even if you were to run a routing protocol still you will not see routes from any routing protocol for these subnets as the administrative distance of connected routes is lower than any routing protocol
Thanks & Regards
Zeeshan Sanaullah
Hi Tharak & Zeshaan,
Yes Correct. I noticed now that all the vlan interfaces with ip address are configured in SwitchA.
So, no need of Routing Protocol.
Advait,
I tested the same setup in PT using ur config & its working fine for me.
And Inter VLAN communication between vlan 1,2,3 is working fine.
Dasuntha
John,
The host should be able to ping the SVI of the corresponding Vlan, if i got your question correct.
The SVI's acts as default gateways to the corresponding Vlan's...so communication between hosts in seperate Vlans also will happen without any other configuration. (Similar to the Router on Switch fundamental)
