URGENT: WLAN disconnecting every 10-15 minutes on windows 7 laptop
Jun 23rd, 2010
hi there
i have 2 laptops, one runs xp home and other one runs win 7 ultimate, both machines have pretty much the same stuff on.
the difference is that with the XP one wireless works great with the web authentication and never disconnects, with the win 7 machine instead, it disconnects me every 10-20 minutes or so, i came up with a trick that is to keep a streaming radio on the background, that way sometimes im connected also for 2-3-4 hours but looks like it times out again after an XX amount of time.
so should i change the MTU value on the win 7 machine? that seems to be the workaround it by reading here and there....happens the very same with either firefox 3.6 and internet explorer 8.
on the win 7 machine i installed TCP-Z driver...... > TCP-Z, Best TCP/IP Patch from http://deepxw.blogspot.com/ i tried to disable it and run some tests, but nothing changes.
help much apperciated, please answer here or to my mail gabrio81ATgmail.com
Trending Topics - Security & Network
