HuaweiSoftX3000 / Cisco AS5400 SIP SIG OK MEDIA NOK
mathieuploton
I'm trying to do a sip call from a GSM --> HuaweiSoftX3000 (for SIG) & Huawei Mediagateway (for Media) --> Cisco AS5400 VoIP gateway --> Sip phone (Sjphone)
The SIG seems to go well but when I pick up, the call disconnects.
*Nov 22 19:26:38.145: //-1/xxxxxxxxxxxx/SIP/Error/sippmh_get_body: Malformed multipart body or missing Content-Type
*Nov 22 19:26:38.145: //-1/xxxxxxxxxxxx/SIP/Error/sippmh_get_body: Malformed body or missing close-delimiter --
*Nov 22 19:26:38.145: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetSdpBody: No SDP data found in body
*Nov 22 19:26:38.149: //-1/xxxxxxxxxxxx/SIP/Error/sipsdp_add_standard_lines: media_src_address is NULL; c-line is not added
*Nov 22 19:26:49.105: //1173/27A392168700/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to find the proper instance for FMTP
SIP: fmtp attribute, level 1 instance 0 not found.
*Nov 22 19:26:49.105: //1173/27A392168700/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to acquire event mask for rfc2833 dtmf relay
*Nov 22 19:26:49.105: //1173/27A392168700/SIP/Error/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Nov 22 19:26:49.105: //1172/27A392168700/SIP/Error/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Nov 22 19:26:49.105: //1172/27A392168700/SIP/Error/ccsip_caps_ind:
filter mis-match, failing call
*Nov 22 19:26:49.105: //1173/27A392168700/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x65B55204
State of The Call        : STATE_RECD_PROCEEDING
TCP Sockets Used         : NO
Calling Number           : 2077839657
Called Number            : 2077800530
Source IP Address (Sig  ): 10.30.6.46
Destn SIP Req Addr:Port  : 10.30.6.10:5066
Destn SIP Resp Addr:Port : 10.30.6.10:5060
Destination Name         : 10.30.6.10
*Nov 22 19:26:49.105: //1173/27A392168700/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729br8
Negotiated Codec Bytes   : 20
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 116
Source IP Address (Media): 10.30.6.46
Source IP Port    (Media): 0
Destn  IP Address (Media): 10.30.6.20
Destn  IP Port    (Media): 5620
Orig Destn IP Address:Port (Media): 0.0.0.0:0
*Nov 22 19:26:49.105: %SIP-3-BADPAIR: Unexpected event 25 (SIPSPI_EV_CC_NEW_MEDIA) in state 9 (STATE_DISCONNECTING) substate 0 (SUBSTATE_NONE)
*Nov 22 19:26:49.105: //1172/27A392168700/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x635B66D0
State of The Call        : STATE_DEAD
Called Number            : 2077827637
Destn SIP Req Addr:Port  : 10.30.6.10:5061
Destn SIP Resp Addr:Port : 10.30.6.10:5061
*Nov 22 19:26:49.105: //1172/27A392168700/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0
Source IP Port    (Media): 16754
Destn  IP Address (Media): 0.0.0.0
Destn  IP Port    (Media): 0
Disconnect Cause (CC)    : 65
Disconnect Cause (SIP)   : 200
*Nov 22 19:26:49.153: //1173/27A392168700/SIP/Call/sipSPICallInfo:
*Nov 22 19:26:49.153: //1173/27A392168700/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Disconnect Cause (SIP)   : 481
*Nov 22 19:26:49.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:26:50.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:26:52.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:26:56.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:26:59.673: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg: Invalid method for (STATE_IDLE): BYE
*Nov 22 19:27:00.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:27:04.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:27:08.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:27:12.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:27:16.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:27:20.605: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_new_msg_preprocessor: Could not find ccb for response
*Nov 22 19:27:21.101: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg: Invalid method for (STATE_IDLE): BYE
dial-peer voice 30 voip
translation-profile outgoing prefix
destination-pattern T
progress_ind setup enable 3
progress_ind connect enable 8
rtp payload-type nte 96 <-- Huawei has 96 payload
voice-class codec 1
voice-class sip rel1xx supported "timer"
session protocol sipv2
session target ipv4:10.30.6.10
dtmf-relay rtp-nte
mathieuploton
I updated the thread, please advice, thanks !
I think the problem is on the supplementary services (hold, pickup,...).
We also experience the same problem without solution from Cisco.
