FWSM cpu utilization
Jun 23rd, 2010
        i have FWSM installed 6500 BB , its S/W 4.0(8).
when we add any ACL line , cpu go from 5% to 95%.the traffic is not affected.
any help please.
Jennifer Halim Wed, 06/23/2010 - 05:57
If you have a huge ACL configuration, adding a new ACL will increase the utilization as it is compiling the ACL in hardware. However, the utilization should go down once the ACL compilation is completed.
Are you only seeing the issue recently after the upgrade to version 4.0.8? if yes, what version of software where you running before when you don't see the issue?
Panos Kampanakis Wed, 06/23/2010 - 15:16
Also not that if you are using ACL optimization then then the ACL recompilation will take a little more time.
I hope it helps.
