06-23-2010 06:49 AM - edited 03-06-2019 11:43 AM
I think it's layer 3 bc of the ip addressing on the SVI. Am I correct or incorrect?
Solved! Go to Solution.
06-23-2010 07:02 AM
Everything that I've found indicates that it's L3.
HTH,
John
06-23-2010 07:02 AM
HTH,
John
06-24-2010 12:26 AM
What i think HSRP is both layer 3 and layer2 because what it does is the same thing does the ARP and Proxy ARP, But as per the operation If you see w it works on layer 3 and provides a standby IP address for hosts on that network to use as their gateway (or other routers to use as a next-hop for a route). Two or more routers are configured with the standby IP on a broadcast interface (usually an Ethernet of some kind), and a passive election is held to determine the active router.
This router answers ARP requests for the standby IP with a virtual MAC address, so every host that sends packets to the standby IP winds up sending it to the active router. If the active router dies, another election is held, and a new active router is elected who answers for the virtual MAC; the hosts never know anything happened.
Hope to Help !!
Ganesh.H
