Aironet 1200 vlan's
Jun 23rd, 2010
I have an Aironet 1200 with 3 SSID's attached to 3 vlan's. I need to create a way to get all vlan's over wireless, to a wireless bridge (WET200), where I can then setup the ports for specific vlan's. I cannot change the aironet over to a bridge. I need to keep the current ssid's set to specific vlan's. Any help on getting the aironet 1200 to do this, would be greatly appreciated. Thanks.
John
gamccall Wed, 06/23/2010 - 07:41
  • Silver, 250 points or more
Making this work for a 1200 to 1200 bridging implementation is pretty straighforward, and there are plenty of docs on how to do this- basically, you're only going to have one SSID running between your bridges, and then set up subinterfaces for each vlan you want to carry across. However, whether this is possible when bridging to a WET200 is a very different question. I'd be surprised if you can get this working as described.
Trending Topics - Security & Network
