2811 High Memory Usage
   We just connected a new 2811 at one of our remote sites.  All L2 traffic is tunneled back to campus via an IPSEC tunnel.  In the last few days I have notice that the 2811 is experiencing very high memory usage (89%).  Currently there are only 6 computers connected to the switch module on the router and bandwidth usage is very low.  How would I determine what is causing the high memory usage?
Mike
2 Accepted Solutions
I don't see the information that I need.
jerry
Looks like CSCta09049 to me. The fix should be in 12.4(22)T5 or 12.4(24)T3.
HTH,
jerry
10 Replies 10
Jerry Ye
Please post the following output
sh ver
sh proc cpu sorted 1 min
jerry
Here you go.  Currently I am showing only 32% memory usage.
Mike
Those commands will help me to find out the problems.
Can I see the show version to see what IOS you are running?
jerry
Here you go.
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
MCC1FRT01 uptime is 2 weeks, 6 days, 22 hours, 57 minutes
System restarted at 12:50:01 CDT Wed Jun 2 2010
System image file is "flash:c2800nm-adventerprisek9-mz.124-22.t4.bin"
Cisco 2811 (revision 53.51) with 505856K/18432K bytes of memory.
Processor board ID FTX1403AJB8
2 FastEthernet interfaces
1 Gigabit Ethernet interface
2 Serial interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
191K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
mike
You might be hitting CSCta09049.
Can I see the output of couple more command?
show clock
show mem stat
show proc mem sorted
show buffers
jerry
Here you go.
Mike
jerry
oops.  Here you go.
Mike
HTH,
jerry
Thanks I will upgrade as soon as possible.  i really appreciate    your help.
mike
