CUPC crashes during username/password authentication
Jun 23rd, 2010
I have a user running a Dell D420 w/ XP SP3 and CUPC 7.0.2.  During the login authentication process for CUPC, the application crashes.  This user can login to CUPC with his un/pw on another computer.  When I attempt it with my un/pw on his computer it crashes as well.  I've also tried a separate profile.  When putting in an incorrect un/pw, it does come back with a un/pw error and doesn't crash.  It seems it happens when it actually authenticates.  I've disabled the AV, removed most of Wave Systems' software except for Document Manager Lite and Personal Information Manager and reinstalled CUPC (twice).  I'm out of any logical suggestions at this point.  Any ideas?
htluo Wed, 06/23/2010 - 09:39
Are you sure you removed "Embassy Security Suite"?
If yes, try to remove the following folders:
%userprofile%\Application Data\Cisco\Unified Personal Communicator
%userprofile%\Local Settings\Application Data\Cisco\Unified Personal Communicator
Thanks!
Michael
http://htluo.blogspot.com
scottbentley Wed, 06/23/2010 - 13:16
Thanks for the response, Michael.  I even contacted Wave to get manual uninstallation instructions to make sure all of their software is removed.  I deleted the folders you recommended and it still crashes after it authenticates   Any other ideas?
htluo Wed, 06/23/2010 - 13:17
Then you'll have to open a TAC case.
Michael
Related Content
