SA540 Upgrade SSL VPN to 50 Seats fails
Jun 23rd, 2010
I have the SA540 and was looking at the licenses.  It has a link to click on to upgrade the SA540 SSLVPN from 2 seats to 50 seats for free.  However when I go to the page and fill out the form I get the following error:
Please correct the errors below and  re-submit the request
SSL_VPN SKU is not supported on  destination device platform SA540,SA540
I have tried entering the product ID differently, but it still does not work.  I am getting the informaiton from the ABOUT tab in the admin console, so I know it is correct.
Anyone else have this issue?
I am running the latest firmware if that matters.
Thank you,
1 vote
afsciscoadmin Fri, 07/09/2010 - 17:38
I am having the same issue and I bought 3 devices that I may have to return or give away.  I spent a long time ( more than an hour) with some support person and he could not help me out. I am starting to guess that Cisco is not interested in the small busines market.
nmanglik Tue, 07/13/2010 - 18:31
Hi Derek,
This issue has been addressed and now you should be able to generate the SSL license for SA540.
hepartida Wed, 07/14/2010 - 10:27
Thanks Nitin, the license update is working fine now.
Best Regards.
nirmal soundarrajan Sun, 05/25/2014 - 08:35
hi ,
When i tried to upgrade the license to the 50 free ssl vpn , it throw an error while processing the license request.
can you please help
please see the attached error detected
