6509 Redundant Sup720-10G to Dual-Chassis, HSRP ideas
We currently have a single 6509 chassis with redundant Sup720 modules. We just purchased a second 6509, and will be moving the secondary Sup720 to this chassis.
I would like to know the "best practices" for setting this up:
1: Inter-switch links - configuration for communication between chassis (4 x Gigabit copper interfaces)
2: Reconfigure from "single-gateway" routing to HSRP, without disrupting client access.
     (can HSRP be set to use ~50% active routed links on one chassis, and ~50% on the other chassis?)
3: Redundant links from external switches (one link to each 6509, both operational?)
     (Note that most external switches have multiple VLANS associated with them, routed and non-routed)
I understand most of the concept, but would like to "fill in the blanks", so to speak, before we start this project.
Any ideas, issues, noted problems, and/or configuration examples would be appreciated. Especially, any "gotchas" that caused problems in making this type of change.
Thanks in advance.
joshiaroon Wed, 06/23/2010 - 11:47
we have just completed same scenario in our company. Two 6509 with dual supervisor and msfc are configured for HSRP.
There is two option
Option  1: Dual Internal MSFCs Operating as Separate Routers
Option  2: Single Router Mode
cisco recommend using option 2. i list the configuration where 6509#2 is active for vlan 1 and 6509# 1is active for vlan 4
6509 #1
interface Vlan1
description Management Vlan
ip address 10.1.6.3 255.255.255.128
no ip redirects
standby 1 ip 10.1.6.1
standby 1 timers 5 15
standby 1 priority 80
standby 1 preempt
standby 1 authentication dc26
interface Vlan4
description Business Vlan
ip address 10.1.4.201 255.255.255.0
no ip redirects
standby 4 ip 10.1.4.1
standby 4 timers 5 15
standby 4 priority 90
standby 4 preempt
standby 4 authentication dc26
6509#2
interface Vlan1
ip address 10.1.6.2 255.255.255.128
no ip redirects
standby 1 priority 90
standby 1 preempt
interface Vlan4
ip address 10.1.4.151 255.255.255.0
no ip redirects
standby 4 priority 80
standby 4 preempt
Related Content
