871W Site-to-Site and Easy Vpn
bartosz.c
I have a problem with configuration Site-to-site and Easy both together on the same router 871W
Something is work but not everything.
x.x.x.x - IP address of WAN
a.a.a.a - IP address of gw for WAN
z.z.z.z - IP address of Site-to-Site VPN
192.168.201.0/25 - LAN
192.168.200.0/24 - addresses Easy VPN
192.168.151.0/24 - Site-to-Site LAN
Site-to-site is working properly, everythings fine, but Easy VPN no.
Configuration of Cisco VPN Client:
Host - x.x.x.x, group auth name - remotegroup, pass *
user test, pass *
I have a successful connection of Cisco VPN Client (I see closed Lock - status Connected)
Connection gave me address 192.168.200.5.
But I cannot see LAN and/or Site-to-Site LAN.
And I do not have any idea what can be wrong.
Finalny config:
Quote:
Current configuration : 8860 bytes
version 12.4
no service pad
service password-encryption
service sequence-numbers
hostname moj-waw-rtr
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
enable secret *
aaa new-model
aaa authentication login default local
aaa authentication login remoteusers local
aaa authorization exec default local
aaa authorization network remotegroup local
aaa session-id common
resource policy
ip subnet-zero
ip cef
no ip domain lookup
ip domain name waw.moj.pl
ip name-server 194.204.152.34
ip name-server 193.178.240.2
crypto pki trustpoint TP-self-signed-*
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-*
revocation-check none
rsakeypair TP-self-signed-*
crypto pki certificate chain TP-self-signed-*
certificate self-signed 01
quit
username user privilege 15 secret *
username test privilege 4 secret *
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key * address y.y.y.y
crypto isakmp client configuration address-pool local TOVPNPOOL
crypto isakmp client configuration group remotegroup
key *
pool TOVPNPOOL
crypto isakmp profile vpnclient
match identity group remotegroup
match identity address 192.168.201.111 255.255.255.255
client authentication list remoteusers
isakmp authorization list remotegroup
client configuration address respond
crypto ipsec transform-set vpntowaw esp-3des esp-sha-hmac
crypto ipsec transform-set vpnwaw esp-3des esp-md5-hmac
crypto dynamic-map DYNAMIC 10
set transform-set vpnwaw
set isakmp-profile vpnclient
reverse-route
crypto map vpn_wro_waw 1 ipsec-isakmp
set peer y.y.y.y
set transform-set vpntowaw
set pfs group1
match address 104
crypto map vpn_wro_waw 65535 ipsec-isakmp dynamic DYNAMIC
bridge irb
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ETH-LAN$
ip address x.x.x.x 255.255.255.0
ip access-group 102 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid TO-WAW
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii *
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0  36.0 48.0 54.0
station-role root
no dot11 extension aironet
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 192.168.201.1 255.255.255.128
ip access-group 101 in
ip nat inside
ip local pool TOVPNPOOL 192.168.200.2 192.168.200.101
ip classless
ip route 0.0.0.0 0.0.0.0 a.a.a.a
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.201.3 80 interface FastEthernet4  80
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet4  overload
access-list 1 remark SDM_ACL Category=1
access-list 1 permit 192.168.201.0 0.0.0.127
access-list 1 permit 192.168.151.0 0.0.0.255
access-list 1 deny   any
access-list 100 remark SDM_ACL Category=2
access-list 100 remark IPSec Rule
access-list 100 deny   ip 192.168.201.0 0.0.0.127 192.168.3.0 0.0.0.255
access-list 100 deny   ip 192.168.201.0 0.0.0.127 192.168.2.0 0.0.0.255
access-list 100 deny   ip 192.168.201.0 0.0.0.127 192.168.151.0  0.0.0.255
access-list 100 deny   ip 192.168.201.0 0.0.0.127 192.168.200.0  0.0.0.255
access-list 100 permit ip 192.168.201.0 0.0.0.127 any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny   ip x.x.x.x 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 101 permit icmp any any
access-list 102 permit icmp any host x.x.x.x
access-list 102 permit udp host 194.204.152.34 eq domain host x.x.x.x
access-list 102 permit udp host 193.178.240.2 eq domain host x.x.x.x
access-list 102 permit udp host y.y.y.y host x.x.x.x eq non500-isakmp
access-list 102 permit udp host y.y.y.y host x.x.x.x eq isakmp
access-list 102 permit esp host y.y.y.y host x.x.x.x
access-list 102 permit ahp host y.y.y.y host x.x.x.x
access-list 102 permit ip 192.168.151.0 0.0.0.255 192.168.201.0  0.0.0.127
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.201.0  0.0.0.127
access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.201.0 0.0.0.127
access-list 102 permit ip 192.168.3.0 0.0.0.255 192.168.201.0 0.0.0.127
access-list 102 permit ip 192.168.201.0 0.0.0.127 any
access-list 102 deny   ip 10.0.0.0 0.255.255.255 any
access-list 102 deny   ip 172.16.0.0 0.15.255.255 any
access-list 102 deny   ip 192.168.0.0 0.0.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 deny   ip 192.168.201.0 0.0.0.127 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip host 0.0.0.0 any
access-list 102 permit ip any any
access-list 103 permit ip 192.168.200.0 0.0.0.255 any
access-list 103 permit ip 192.168.151.0 0.0.0.255 any
access-list 103 permit ip 192.168.201.0 0.0.0.127 any
access-list 103 permit ip 192.168.2.0 0.0.0.255 any
access-list 103 permit ip 192.168.3.0 0.0.0.255 any
access-list 103 permit ip y.y.y.y 0.0.0.7 any
access-list 103 deny   ip any any
access-list 104 remark SDM_ACL Category=4
access-list 104 remark IPSec Rule
access-list 104 permit ip 192.168.201.0 0.0.0.127 192.168.151.0  0.0.0.255
access-list 104 permit ip 192.168.201.0 0.0.0.127 192.168.2.0 0.0.0.255
access-list 104 permit ip 192.168.201.0 0.0.0.127 192.168.3.0 0.0.0.255
access-list 104 permit ip 192.168.201.0 0.0.0.127 192.168.200.0  0.0.0.255
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 100
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 103 in
privilege level 15
transport input ssh
scheduler max-task-time 5000
end
Marcin Latosiewicz
Bartosz,
If you want to ping device on the other side of IPsec L2L tunnel you need to modify your ACL 104.
to read
permit ip RA_VPN_POOL SUBNET REMOTE_SUBNET REMOTE_SUBNET_MASK.
access-list 104 permit ip 192.168.201.0 0.0.0.127 192.168.200.0   0.0.0.255 <---- this means .. put into the static L2L  tunnel traffic from my local subnet going to my remote access VPN ... seems bogus
Marcin
6 Replies 6
Marcin Latosiewicz
Bartosz,
to read
Marcin
I have modyfied acl 104 as you suggest:
access-list 104 permit ip 192.168.200.0  0.0.0.255  192.168.201.0 0.0.0.127
It is working, thank you.
But, do you know why after connecting through Easy-VPN I do not have any access to outside world (no ping to f.e. google.com)?
I alaways thaught that such connection looks like below scenario:
route INSIDE_LAN through VPN_TUNNEL
route EVERYTHING_ELSE throug LOCAL_INTERFACE
but it seam I was wrong, was I?
Marcin Latosiewicz
Well... how about NAT for example?
Since traffic is arriving on same interface it might be a problem.
I would suggest to turn your ezvpn server into DVTI.
Once you have DVTI setup, you apply "ip nat inside" on the virtual-template interface and voila
Could you give me any link to sample configuration? I've never did such configuration before.
Thank you very much.
