6509 Sup HOT in rommon
Jun 23rd, 2010
hi, i have a Cisco 6509 and after to introduce the command "hw-module module 6 reset" in order to perform a reset, this module turn to rommon mode.
after that if I introduce de comand "boot" the module turn in HOT STANBY mode.
I attach some captures.
Overall Rating: 5 (1 ratings)
Brandon Lynch Wed, 06/23/2010 - 13:49
Is the configuration register set correctly on the standby's SP?  Please do the following and attach the output -
1) attach 6
2) show version
Your output also suggests that the standby console is disabled so you may need to enable it from the active SUP before trying to run 'show version' from the standby card -
Router(config..)#standby console enable
