IPV6 and failover 8.0.4
Jun 23rd, 2010
we are getting the following messages in our PIX with 8.0.4 SW version:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} %PIX-6-110002: Failed to locate egress interface for UDP int_inside:IPV6add to IPV6add2
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} %PIX-6-110002: Failed to locate egress interface for TCPint_inside:IPV6add to IPV6add2
this only happens when we have the PIXs in failover, if we put it in standalone both work without this problem..
failover it's already supported with IPV6 configured?
Thank you.
Marcin Latosiewicz Wed, 06/23/2010 - 10:07
Norberto,
IPv6 failover is supported as of ASA (not PIX) version 8.2.2
Do you receive those messages on active unit?
Marcin
Norberto Salgado Wed, 06/23/2010 - 10:13
We have the failover configured in ipv4 but we are using ipv6 also..is failover unsupported in this scenarium? Or it's just unsupported if we have the failover configured with ipv6 addresses?
Marcin Latosiewicz Wed, 06/23/2010 - 10:26
Norberto,
Before 8.2.2 both active and standby unit were using same IPv6 address which is already quite interesting for say management purposes
Marcin
