NAC with, WSUS Slow performance.
Jun 23rd, 2010
Folks,
I am trying to use the NAC with WSUS requeriment type but I am experiencing some problems with slow
performance to verify users.
I am using Severity mode and some machines have for about 2 minutes to pass trough posture assessment and
others machines for about 4 minutes.
Does anyone know how can I narrow this time?
I tried to use these tricks on web site
http://security-blog.netcraftsmen.net/2008/11/solution-for-slow-cisco-nac-wsus.html
but withou success.
What are you doing to narrow this time?
thanks a lot
blaxucisco Wed, 07/14/2010 - 23:22
Hi Danielnunes,
I also have same problem, did you get any solution of this problem? Please let me know
Thank you
Laxman
danielnunes Thu, 07/15/2010 - 06:18
Hi My friend,
now I am testing WSUS requeriment using the Cisco rules instend of use Severity.
This way you need to map the e.g. HOT_FIX_XP to your WSUS requeriment.
You will see many differences about time, isvery quickly.
let me know what's your feelinkg about this way.
thanks
blaxucisco Mon, 08/09/2010 - 00:10
Hi Danielnunes,
Thank you for your suggestion.
@Faisal,
I need to configure severity instead of cisco rules but having performance issue. I did as per the blog but nothing happened. Could you please suggest me what should I do for better performance?
Thank you
Laxman
