Deployment Question
Jun 23rd, 2010
Running into a situation that I need some clarification on.
in  a 5.2 environment and 4400G DMP's
have deployed a presentation to  the DMP and have issued a Local command to have the DMP play from  local.
I then go back into the presentation and make a change,  like adding a new jpeg to a playlist.
I save the presentation  then go to the DMP Manager and deploy the package again.
I have  verified that the new jpeg file is on the DMP, but the presentation is  still playing the previous set of commands.
When will  the DMP relook at the presentation command file?
abcronin Sun, 12/09/2012 - 15:32
Hi Richard, I have the exact same issue, did you get this resolved, was it a known bug?
I have a customer using 5.2.1, i know its old
Leo Laohoo Sun, 12/09/2012 - 16:10
Contact your authorized reseller and ask if you can get a copy of the newer 5.4.
Marco Cassini Mon, 12/10/2012 - 02:46
Hi Richard, Andy,
Did you try to push again the LOCAL presentation to the DMP after deploying the package again? It is always recommended to do so after re-deploying a package, as that would force the DMP to reload the assets.
abcronin Mon, 12/10/2012 - 11:40
Hi Marco
Yes Once I do a 'deployment package' I run a go to url command to play the local content but the html (script) file is referencing old assets that are no longer in the presentation.
Not sure what you mean by 'push again the LOCAL presentation'.
5.4 doesn't seem to be on CCO as yet, the customer is in process of upgrading to 5.3 anyway but I was trying to find out if it was a known bug.
Marco Cassini Tue, 12/11/2012 - 00:59
Hi Andy,
With "push again the LOCAL presentation" I meant indeed to run again the go to url command to play the local content after the "deployment package" is completed.
If you have already done so, this may be a bug indeed. If the problem persists after the customer has upgraded, you may open a TAC Service Request to investigate this further.
5.4 will not be published on as it is a paid upgrade, except for customers with SAS contract. SAS customers will be able to download the software via the Product Ugrade Tool (PUT).
panayiotiscy Tue, 12/11/2012 - 01:28
Hello ,
I can remember facing this issue as well.
What i did to overcome this situation was to format the flash memory of the dmp before every new deployment.
You need to create and advance task and use SET option along with this string:
Then, you can just deploy the desired package.
Let me know if it works for you also!
abcronin Tue, 12/11/2012 - 11:50
Thanks for the reply's guys I appreciate it.
Thanks for that string I was wondering how that was done, I deleted the deployment folder using FTP so it had the same effect.
I will also request the PUT upgrade for 5.4.
Related Content
